fuel pump change help!!
changing my fuel pump on my S1
got the 2 pos and neg leads off, and got the banjo off, clamped the small hose which leads to the banjo.
but my pump is spewing out petrol.
is the small hose at the front off the pump supposed to be clamped also??
or should i expect the pump to leak fuel out??
fuel pressure realesed and battery undone.
help apprieciated.
and the small 5 cm or so on (thick one) is the inlet pipe yes??
Alright mate.
Right, im a bit confused, but basically, the rubber hose from the tank is the inlet to the pump, and the thin hard plastic hose is the outlet. They will both spill petrol, but the rubber one could spill shitloads depending on how full the tank is
cossie09
14-09-2015 04:21 PM
CabrioTurbo
01-08-2015 11:04 AM
