2 stage ECU
How much do these cost, and particular ones that are better. Can you set the 2 boosts settings at whatever you like. How do these work techicanlly. I know a bleed valve just blows out some of the air. Im thinking thats pretty pants !
Not sure what you mean by a stage 2 ecu..
If you get a proper rs turbo chip, then this will be able to see up to about 1.2-1.3 bar correctly.. having different boost levels is up to you really, it's pretty simple to have low/capsule boost (eg, 10-12 psi) and high boost (up to 23 psi) just by putting a switch on the amal valve..
put a switch between the amal valve and earth
it will half and double the desired boost but as said above adjust your actuator to get maximum boost level first
this way it wont boost beyond your maximum boost level!
Adjusting actuator arms to control boost is a bad thing.. half a hole of preload is what you want, then you jet your amal valve to achieve the desired max boost..
and what if you dont even run with an amal valve?
JK12
33
26-04-2021 12:09 PM
Mc5506
05-10-2015 09:57 PM
