Please please help, im really desprate.
Went to start my rs today for the first time after buying it.
It started ok and i left it for a couple of minutes and it was idle ing a bit crappy, i gave it a few revs to about 1 and a half rpm then let off and it was trying to die, i then took it to about 2rpm then let off and it cut out. Please can anyone give me any idea what could be wrong with my car. This really hacked me off as ive only just got it.
Ive got to go to a bbq now but as i say pretty pretty please leave your suggestions and i will get back on asap. Thank you all very very much
i had the same problem with my old rs ended up being my fuel metering unit but then that was just mine could be a number of things, sumone should know on here.
Originally Posted by adamS2RST
Sounds like you bought a dog to me ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Check for split vacum hoses and try adjusting ur idle mixture!Its a process of elimination...
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
check dipstick is in the tube correctly ,check oil cap is on tight , check all boost hose clamps are tight as rs turbo engines dont idle with air leaks
Thank you all very much, im going to have a swift look over simple things on the car such as plug leads etc, and then if i have no joy im going to take it to well-lane in leeds (its only 5 mins away) and get them to have a look and sort it out. Adam, maybe your right, mabye your wrong only time will tell, but obviously i hope i havent and im pretty confident it will all work out in the end.
