fuel pump problems
Old Jun 10, 2006 | 07:00 PM
Sean Davie's Avatar
Sean Davie
Default fuel pump problems
my rst keeps seizing fuel pumps, a'v done 25 miles since a re-build and went through 3 pumps, am on pump no 4 now, getting fitted tomorrow. it's a new tank and a'v cleaned out the fuel lines. has any any idea's please
Old Jun 10, 2006 | 08:29 PM
SafeChav's Avatar
SafeChav
Do you have a habit of running it in the red?
Old Jun 10, 2006 | 08:51 PM
Sean Davie's Avatar
Sean Davie
everytime a'v changed a pump, a'v drained the tank and put n 20liters of fresh optimax, a'v also removed the tank and cleaned it out, a noticed alot of shit coming out of the fuel that a drained out it, it must be coming from the return, but a'v cleaned the fuel lines out. and it still happenin
Old Jun 10, 2006 | 09:48 PM
SafeChav's Avatar
SafeChav
I'm fairly sure the swirl pot has a gauze in it. What i meant was do u run the car in the red section, i.e when its about to run out of fuel
Old Jun 10, 2006 | 09:59 PM
Sean Davie's Avatar
Sean Davie
a'v never had the car running long enough m8, 1st run a got 10mile and it packed in, so a got a brand new pump and it lasted bout 20 mins then packed n same with the 3rd pump, and am putting twenty litres n every time a change the pump. so it not really getting to low on fuel. hav had the new tank out twice and rinsed it out, a dont think my swirl pot has a gauze in it, tak it, it should hav?
Old Jun 10, 2006 | 11:51 PM
MikeyXR2i's Avatar
MikeyXR2i
whats the pump sound like when its running? Stressed??
Old Jun 11, 2006 | 12:00 AM
Sean Davie's Avatar
Sean Davie
them pump sounds fine, there brand new as well. it jst cut's out wi no warning, then thats the pump fooked
Old Jun 11, 2006 | 12:06 AM
MikeyXR2i's Avatar
MikeyXR2i
how u know its actually seizing it, you have tried turning the gubbins in the pump have you? Will it not turn?
Old Jun 11, 2006 | 12:42 AM
Sean Davie's Avatar
Sean Davie
ye tried turning them, tried a power probe on them, 2 try and give them a surge 2 free them off, no joy. stripped 2 of them down 2 see if a clould see wot was jamming them, but they seemed to free off wen a got half way through the gubbing it's not the motor thats seizing its the bit the motor turns.
Old Jun 11, 2006 | 08:35 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
sounds a sod, i have a second hand 1 for Ł25 posted if you need 1 (got about 10 actually ) have a couple of tanks too but not keen on posting
run 2 new fuel lines down the car and start over with all good parts again ive not heard of a pump siezing tho, usually its the internals that wear out and wont flow the fuel at any pressure
Old Jun 11, 2006 | 12:01 PM
SafeChav's Avatar
SafeChav
Thats very wierd fault.
U sure its not a knackered fuel pump relay???? Just thought a thought cos thats unusual having so many pumps go in a row
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
