fuel ajustment on the metering unit (S1)
Audio specialist
hi peeps, does anyone know how to ajust the fuel on the metering head for more fueling on boost as mine is a tad lean, AFR meter saying very lean on boost....oppps.
its only doing 12.5 psi......so it should cope with that.
i turned the boost down to 8psi and its still a tad lean.....
and please dont just say GO AND GET IT SET UP, as i want to learn this myself,,,
cheers my fellow ford lovers....
Its not very easy Lee, u can do adjustments to the hydro electric pressure actuator, and you can do the vacuum pipe to pressure regulator mod, neither of which i would have a stab at and hope for the best
Originally Posted by SafeChav
Its not very easy Lee, u can do adjustments to the hydro electric pressure actuator, and you can do the vacuum pipe to pressure regulator mod, neither of which i would have a stab at and hope for the best ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Hydro - does ur run on water
And go and get it setup - ur gauge is next to useless...
Originally Posted by Rick
It's electo magnetic pressure actuator u pleb
Hydo - does ur run on water
HYDO?????
Who's the pleb now, BITCH
![Content](https://passionford.com/forum/images/smilies/content.gif)
It's electo magnetic pressure actuator u pleb ![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Whats Electo???
Is that something to do with selection
Audio specialist
the thing is i want to learn how to do this and dont just want to go to a tuner and let them get on with it, i have the right kit to do it ,det headphone amp ect....
what vacume pipe to the fuel reg......how the fook does that work??? anyone got a link or sumit???
155lee
24-10-2015 11:11 AM
