A few points.
A few points.
I got my first RS a couple of months ago (escort rs turbo) I'm very happy with it, except for the brakes which are fookin frightening, a not uncommon problem! they are standard.
The main thing is a horrendous shuddering through the steering wheel under heavy breaking
Having spoke to a few people about this and with a limited budget, and not knowing very much about rs modifcations, am I best to go for cosworth 2wd discs, with a bracket for the standard calipers? if so do I get ford discs or for example EBC, or what?
Pads? Whats best to use your advice and help would be appreciated.
Also I would like to give it a service, change the oil,(do i use synthetic, semi, fully ? plugs, air/oil filter.
Which bits should I use and where to get them?
Thanks alot in advance
I
I
is this my old one mate?
Spoke to you a while ago about it, brakes need sorting sharpish just trying to get some ideas from people
thought that was you, couldnt remember username exactly
like i say mate, cossie setup is what i was going for, just bought a set for Ł200 all in which aint bad.
depends how good your calipers are really - you may get away with just fitting the 2wd discs and getting some brackets off www.randbmotorsport.co.uk and keeping std calipers.
otherwise get em reconned - im not sure on their condition never checked
Redumbdancy
Don't forget to upgrade to braided lines and dot 5.1 fluid too
Sounds like warped disks but i hope the wheels aren't buckled - damn roads around here, worst in Britian
BLACKCOS
21
20-11-2008 07:01 PM
