Are these cosworth calipers??
This is whats on my car
Paid £90 for mintex 1155 pads for an rs turbo and they didnt fit!
The mechanic who done them says hes put granada pads in them and thats what fitted, was this because saff cos calipers and granada ones are the same fittment or do i have a granada convertion
Help please cos i have a set of £90 pads i dont know what to do with
http://i38.photobucket.com/albums/e1...e/DSC00198.jpg
http://i38.photobucket.com/albums/e1...e/DSC00197.jpg
cheers mate thank you very much.
Just hope Questmed dont mind me swaping these rs turbo pads for the 4x4 saff ones.
By the way, how come granada pads fitted these calipers? they the same then?
calipers r the same i think but bolt fixin bolt sizes r bigger on granada... hence y i had to drill out my mounts a bit bigger to bolt mine straight up (with 1mm spacer between hub n caliper)...
open an account on www.photobucket.com
up load the pic... then copy past the 'IMG' link and put it in ur sig in ur profile!
job done!
job done!
Originally Posted by Jano_OddKidd
Yes they are 4x4 front calipers. But are also the same as many other calipers fitted to other cars.
The way to tell is by looking at the hole in the caliper. The shape of it gives away what it is.![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
yes mate there cossie calipers they look like 4x4 one's if there should be numbers on each caliper one will be higher than the other for example gn27 and gn28 but im 99% sure there cossie calipers
JK12
33
26-04-2021 12:09 PM
