boost problems, please help
Old Apr 20, 2006 | 10:25 PM
nistec's Avatar
nistec
Default boost problems, please help
bought a s2rs and it is running 16 psi through standard cooler, so wanna drop it til i get a new intercooler
i went to do this via the bleed valve and no matter how much i screwed it it made no difference hardly
as the car is now, it runs 16 psi until you flick a switch inside the car, after doing so it flies past 20 and pinks its arse off, the car also has a 5th injector, the electrics are disconnected and the fuel line is bunged up
here is a brief description of my boost system, i tried drawing a picture but it didnt happen
there is what i can only think to be a boost sensor (pic 1) above the fuse box, from which goes a hose that goes to a t piece, one end goes into the car (i suspect boost gauge) the other then goes onto the top of the manifold (left hand side pic 2) the right hand side pipe then dissapears behind the engine, dunno where to, and it has a t piece to the top of the dump valve.
from the turbo a pipe goes into the bleed valve, (left hand side pic 3) the centre hose from the bleed valve runs to the electrical unit in pic 4 (from which is one earth and three other wires to a relay and a few other places, dont really know) . the other (right hand side) then runs to an electrical unit attached to the gearbox
so whats wrong guys? any ideas?
pic 1
pic 2
pic 3
pic 4
heres all the 5th injector setup
on the electrical unit on pic 4 there are 2 blanked off parts i am left to believe this injector hose and fuel feed run to but im not sure
Old Apr 20, 2006 | 10:32 PM
notSteveS2's Avatar
notSteveS2
Old Apr 20, 2006 | 10:33 PM
notSteveS2's Avatar
notSteveS2
shud realy be runnin a amal valve instead of bleed valve anyway IMO matey!
Old Apr 20, 2006 | 10:43 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
cant you connect the 5th injector fuel supply and just keep the electircal unplugged, be a bit safer imo!?
i'd ditch all the crap and pipe it back standard till you get it all sorted properly!?
Old Apr 20, 2006 | 10:48 PM
notSteveS2's Avatar
notSteveS2
me too... rip it all out... blank injector whole or change charge carrier and run standard way til u get sorted mate... as above!
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
