holding back
holding back
rite my s2 is holding back under load now and again its runnin a bar of boost chipped big intercooler air filter exhaust ect ect 1min will go like stink then it feels like its choked up done the plugsstill the smae dump valve was leakin disconnected it still the same.............. feels like the boost hoses are colapsing but it got silicon efforts on it..... any ideas???????
Audio specialist
i had the same trouble in my first s2 and i turned out to be the ecu not advancing and retarding the ignition sometimes it would do it every now and again, i cured it bye cleaning all the conections to the ecu and re-soldering all the iffy lookin joints inside the ecu unit,....worked a treat!! give it a go ...nothin to loose..L
Audio specialist
that would suggest either what i said earlier, OR your fuel pump not creating the full demand at full boost thus going lean...maybe.... more likely to be the earlier idea tho mate.
nice one mate thanks ill spend some time on it over the weekend ud of thought id of learnt buy now how much they rob ya after 2 rsts and a cossy lol
cheers jano just p.m'd u...... was also thinkin ig retard ma self but was also thinkin hoses after hearin wot sounds like air gushing out????? weird
Worth checkin the throttle position switch is working, thats what tells the ECU to give full load enrichment......nothing else. Common for the solder joints inside to break down and go dry, i had the exact same problem.
ok so ive took the top hose off its got oil init........ but im not burning oil just a litte puff on over run its still using a standard breather system and runnin a bar of boost so the next question is turbo or breather??????? i know on my cossie it was the breather making it smoke help
Turbo is my answer......oil in the CROSSOVER pipe and smoking on over run can be nothing but, theres usually oil in the lowest boost pipe, but to get it in the top one is something else......
tis turbo had the hoses off and theirs more play in the shaft than god knows wot........ tis all good though ive found my self a nice stage 3 turbo thats a year old and only seen 8k since it was built for 200 quid its a technics effort 2
road trip tonight off to fetch the turd blower just hope its as good as the dude says funny thing is now ive agreed to buy it shes not smokin or holdin back lol
it's not the turbo that is making it hold back. Oil in the crossover is common - and defo isn;t the turbo, as the compressor seal doesn't leak. It's oil from the breather as it is plumbed into the metering head.
