dash gauges inverter
Old 11-10-2006, 03:11 PM
  #41
markthomo
markthomo's Avatar
Hi Tandy
Ive got the same problem as u at the moment...........ur thread has been unreal because it has hopefully given me the answer to fixing it. I have pulled all my gauges out to get a better look at the inverter.....mine seems to still have a firm connection on the blue circuit board. Do u believe that the problem with urs was the inverter being faulty or that it just had a bad connection on the blue circuit board?
Old 11-10-2006, 06:54 PM
  #42
Twinny
Twinny's Avatar
am havin problems with mine
were about is the invertor behide the speedo clocks or the boost clocks
Old 11-10-2006, 06:55 PM
  #43
Azrael
Azrael's Avatar
Speedo clocks.
Old 11-10-2006, 07:06 PM
  #44
Twinny
Twinny's Avatar
cheers mate
Old 11-10-2006, 07:12 PM
  #45
Azrael
Azrael's Avatar
4 screws, remove clocks sourround, then 4, remove clocks a bit, remove speedo line, unplug multiplugs, remove clocks, a bit tricky with steering wheel but not impossible.
Old 12-10-2006, 07:54 AM
  #46
Duca
Duca's Avatar
And if you want to work more easy when you have finished to remove the screws then open the bonnet and push the speedo cable.
Old 12-10-2006, 09:36 AM
  #47
Azrael
Azrael's Avatar
I forgot about this - this helps, although I don't know what is access to those in RHD car like, in LHD accesing speedo cable is not easy.
Old 12-10-2006, 05:45 PM
  #48
Twinny
Twinny's Avatar
took clocks out ,strip them down(not easy).
invertor comes tomorrow
Old 14-10-2006, 05:24 PM
  #49
S.Hannah
S.Hannah's Avatar
Twinny.
where are you buying your inverter?
cheers M8
S.Hannah
Old 14-10-2006, 07:05 PM
  #50
Twinny
Twinny's Avatar
hi mate ring this number 08457201201
and ask to register takes a few mins
then quote this number (267-8863)
cost £35 quid all in
Old 14-10-2006, 07:20 PM
  #51
DazC
DazC's Avatar
RS Components!
Old 14-10-2006, 09:08 PM
  #52
cosworth3d
cosworth3d's Avatar
i have the same problem with my speedo , if the speedo lights dont work my boost volt en oil pressure lights dont work either.
is this inverter the same as the inverter i found behind the MPH gauge ??
thanx
Old 14-10-2006, 09:16 PM
  #53
Twinny
Twinny's Avatar
yes it will work
look at the diagram
Old 14-10-2006, 11:02 PM
  #54
S.Hannah
S.Hannah's Avatar
Thanks Mate Ill Do It First Thing Monday Morning.
S.Hannah
Old 15-10-2006, 06:04 PM
  #55
Twinny
Twinny's Avatar
put clocks back in today ,spot on
Old 26-03-2009, 07:41 PM
  #56
cosmo V6
cosmo V6's Avatar
Old 08-06-2009, 05:03 PM
  #57
Pib
Pib's Avatar
Reviving an old thread here.....
I'm in the same position, dash lights are about 90% out, only bit illuminated is the area around the 30mph - 40mph zone.
Occasionally the dash lights come back to life but it doesn't last long.
Anyway, got myself the inverter from RS Components and started taking my dash to bits.
Bit fiddly but got there in the end only to stumble across a wee problem - the speedo cable.
How do you go about disconnecting this?
Is it like a push lock or threaded type connection?
I don't want to be too harsh on the cable and damage the clocks.
Any help would be appreciated.
Pic of the speedo cable connection:
Old 29-08-2009, 10:24 PM
  #58
mtommi
mtommi's Avatar
what is the reason for the loop with the blue wires I have done all this exactly as done in the diagram my gauges light up ok but not very bright except for the speedo which is perfect. When putting the whole thing together again lighting was good untill I connected the speedo and it seemed to soak up all the power they are all working ok but there must'n be enough power goin to the inverter or am I loosing power with that loop as this inverter has 4 pins as opposed to the oe. items 3 pins? please help thanks folks.
Old 29-08-2009, 10:28 PM
  #59
mtommi
mtommi's Avatar
push it to the one side pivoting on the speedo itself
Old 16-10-2010, 12:02 PM
  #60
gingejp
gingejp's Avatar
Thanks to al you guys that have contributed to this thread. My clock lights were out too and fixed them with teh part from RS components. Cheers guys.
Now to find out why my washer bottle lamp is on all the time (somebody had removed the lamp).
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Fordmad!
29-09-2015 07:03 PM
IainRS1700T
25-09-2015 06:44 AM
CrOwSoN15
14
03-09-2015 12:21 PM
Quick Reply: dash gauges inverter
