center console
center console
i no longer have the standard immobiliser on the car and was wondering if anyone had for sale the l.e.d and the plasic surround the immobiliser key goes into just to tidy up my center console thanks for any help
pic should explain things
there's a clock on ebay at the mo and i think you can get the vent panel from fords, i need a new vent panel as well took some of the red paint off the heater dial when using a cotton bud to clean
i dont want to buy a new console just sort the one ive got but thanks anyway
Cosmagedon : Whats up with your clock ?
cheers
the "centre vent dash bit" is the same as any mk 5 esc (well nearly) ....the up/down direction arrows for heater are opposite way round... and the std item has a coin tray... when you get a clock, just cut the back off the coin tray and slot it in.. job done
Originally Posted by Tandy
yep it i think fords do them(heater panel ) the clock will be hard to get hold of cheap. i know north yorkshire rs spares have a couple though
cheers
apparently the vent panel at ford is no longer available for the cossie...one of my customers bought a standard escort one and i trimmed the back off the little holder and fitted the clock in ....it looks spot on
hope that helps
hope that helps
its got the number plate and Escort RS Cosworth on it, not to everyones taste i see, which is fair enough. ive not given it much thought if it should stay or go, it's been on car since the day i got it
1 Post
i used a cone cutter ( a hole saw would do just aswell ) to open the area up to about 1" across which enclosed the original hole and imobilser slot, then fitted a textured grommet like this into the hole, looks almost factory...
these from R do the trick nicey, obviously u would needto measure exactly the correct size..
i have used these to fill old LED holes and imobilser holes etc in the rest of teh dashboard, they fit nicely and are the same colour
http://documents.rs-components.com/i...82088956369113
1 Post
Originally Posted by cozzymatt
I bought a brand new one from fords... Ł82 incl the gaitor!! dint think that was too bad..
Matt
Matt
1 Post
pics of the blanks fitted in mine...
strangely though... all the plastic look different colours, must be the over exposure of the flash cos they defo dont look odd like that in real life
Take this pic as an example
The radio and slot below is black
the gaitor is black
the gearstick/knob is black
the windo switch is black
the leather is a slightly different shade to console,
the console itself is a VERY VERY dark blue, when I have mixed the colour I used dark blue with a dash of black to bring it down even further, IIRC I also used a dash of Dark green...
Look at the ashtray, difeerent manufacturing process, different material different shade of BLUE
the gaitor is black
Spot the difference OK different light conditions (you can see that from the carpet colour LOL) different angle...
IF anything I may have added a little too much black Though obviously in the car it doesn't notice BTW I DID NOT spray the whole console, just the repair
07-10-2015 12:56 PM
Fudgey
17-09-2015 01:06 PM
