fuel pump question!!??
From: brum/shropshire drives:- frst / escort cossie
hiya guys you know i have a ecossie but also own a frst i have fitted a sierra sapphire pump in my fiesta turbo due to running a fuel cell, basically i need to connect the fuel line to the pump but the pump has a threaded pipe on with holes in it looks like it needs some sort of banjo ????
basically i'm unsure what to do to make it fit so ANY advice would be great whether i can unscrew the pipe and fit something else or using the correct fitting?? i have looked for the correct fitting but came out crap so looking for advice.... posted this in the sapphire room and got nothing thats real useful
cheers Ad
cheers Ad
just take the pump to a union / hose place, find out what thred it is and get em to make you a hose... run it to the filter then to the rail, have a look through RichPons resto thread to see what I mean..
BTW he can supply you witht the fittings tooo
i have everything damo its all in filter and all its just i'm left with the pump thread and the fuel line but the thread is about 13mm and my fuel line is 8mm so basically i need a adaptor or something
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
