Heater Matrix
Heater Matrix
Has anyone got any advice on how to tackle changing the heater matrix. I snapped off one of the pipes through the bulk head when taking the engine out Ive heard different ideas on how to go, some have said drop the entire dash forward and ive also heard remove the centre consloe and pedal box and it should slide out. Any help?
mate, that is a complete shit to change!!
i snapped one of my nozzles off trying to pull the pipe off!
i tried loads of things but in the end i had to take it to ford to be done.
it cost me £220 labour!
they had to take the whole dash out to do it.
good luck mate.
good luck mate.
It CANbe done without removing Dash
I took seat and centre console out and did it while I changed a clutch rachet...
Dropping out the steering colum etc will defo make it possible with dash insitu...
dash does have to come out ... not as bad as people make out really i have done a few though and that helps just be very carefull if you have airbag model... 15 mins of battery disconnected befor releasing from wheel
@damo V:
can you tell me exactly which parts i further have to remove to change the matrix on my lhd?
the 4 airhoses are off the box and also the screw on both sides.
i can move the box, but not enough to get the matrix-pipes thru the firewall?!
thanks,
phil
thanks,
phil
done this very job last month, heater matrix had split. it is shit of a job the thought of taking the dash off but wasnt too bad in the end? i think u can take the heater matrix out with out removing the dash... but it would be a fiddle,. easier o take dash out so u can see everything.
take the bottom dash out to much mucking about undo the two big 17 mm bolts then enough to move and replace when the hoses are disconnected !
Where r u ?
Where r u ?
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
