P8 wiring loom diagram
As title, does anybody have a wiring diagram for a large turbo escort. Only reason I ask is that my small turbo has been converted to large turbo but they have used what looks to be a 2wd loom. I have a 2wd diagram but need to know the pin outs so that i can have the reset plug? wired in for my P8. Cheers Steve
Ok, this is correct as per Ford wiring diagram for the Escort Cossie large turbo....
Pin 1 - Earth (brown)
Pin 19 - Earth (brown)
Pin 2 - Lambda sensor (brown/white)
Pin 20 - Power (red)
Pin 3 - Crank position sensor (brown/yellow)
Pin 21 - Not used
Pin 4 - Crank position sensor (green/red)
Pin 22 - Knock sensor (blue/yellow in shielded cable)
Pin 5 - Distributor phase sensor (green/yellow)
Pin 23 - Distributor phase sensor (black/red)
Pin 6 - Knock sensor (black/yellow with brown earth from shield)
Pin 24 - Pin 3 Ignition module (Black)
Pin 7 - Canister purge valve (brown/white)
Pin 25 - Pin 6 Ignition module (black)
Pin 8 - Electronic control loom (blue/white)
Pin 26 - Not used
Pin 9 - Connected throttle pot wire (Pin 30 red) (white)
Pin 27 - Electronic control loom (blue/yellow)
Pin 10 - EFI power relay pin 85 (relay 8) in fuse box (plug M3BB at fuse box) (blue/yellow)
Pin 28 - Fuel pump relay pin 85 (relay 9) in fuse box (plug M5B at fuse box) (blue/gree)
Pin 11 - Map sensor (shielded) and link to common connection* (brown/green)
Pin 29 - Coolant temp sensor (black/green)
Pin 12 - Not used
Pin 30 - MAP sensor and throttle pot sensor (red)
Pin 13 - Octane adjust (black)
Pin 31 - Air charge temp sensor (red/green)
Pin 14 - Octane adjust (black)
Pin 32 - Injector 2 (brown/black)
Pin 15 - MAP sensor (black/red)
Pin 33 - Injector 3 (brown/black)
Pin 16 - Boost valve (brown/yellow)
Pin 34 - Idle speed control valve (brown/yellow)
Pin 17 - Throttle pot sensor (black/red)
Pin 35 - Injector 1 (brown/black)
Pin 18 -Injector 4 (brown/black)
*Pin 11 (brown/green) connects to the following....
Coolant temp sensor
Throttle pot sensor
Aircharge temp sensor
Pin 21 - Not used
Pin 26 - Not used
Pin 12 - Not used
Coolant temp sensor
Throttle pot sensor
Mark RS
12-10-2015 06:01 AM
muz
30-09-2015 08:29 AM
Fudgey
17-09-2015 01:06 PM
