DIFF SOUND ??
Old Nov 30, 2005 | 07:12 PM
cos jon's Avatar
cos jon
Default DIFF SOUND ??
Just noticed a noise like a humming coming from the rear axle when i turned my radio off. It gets higher in sound the faster you go its not loud at all but something i have never noticed before.
If you dip the clutch when moving its still there and if you accelerate and back off the note doesn't change, its seems that its in relation to road speed.
Is it the diff, or is it a normal 4x4 sound ??
Old Nov 30, 2005 | 07:49 PM
Damo V's Avatar
Damo V
Could be the propshaft UJ ... best get it up in the air ASAP and get it checked...
Old Nov 30, 2005 | 08:54 PM
escossie560's Avatar
escossie560
might be worth checking your wheel bearings as well
Old Nov 30, 2005 | 08:56 PM
Damo V's Avatar
Damo V
they would usually "hum" at atround 40 mph
Old Nov 30, 2005 | 10:02 PM
Simon Day's Avatar
Simon Day
Get it sorted before something goes bang!
Old Dec 1, 2005 | 12:36 PM
cossie_love's Avatar
cossie_love
i would also suggest all of the above
but i had the same thing and it turned out to be the exhuast rubbing on the shaft after i lowerd it
best of luck
Old Dec 1, 2005 | 01:58 PM
Damo V's Avatar
Damo V
true.. the exhaust DOES sit VERY close to main prop UJ by diff..
Old Dec 1, 2005 | 05:44 PM
cos jon's Avatar
cos jon
Just took it for a spin and also noticed on hard right turns the left rear wheel sounds a bit noisy, I suppose that points to the CV or wheel bearing ??
How can you tell if its the inner or outer CV or wheel bearing ?
Old Dec 1, 2005 | 07:35 PM
auralisRS's Avatar
auralisRS
Was it definetly the rear wheel, front wheel bearings noises are applified on turning depending on which wheel has the worn bearing.
You could take the bearing out smear it with some high temp grease, replace it and run...if it shuts up temporary then comes back after 15 mins...then its a safe bet you found the culprit...
Best of luck
Old Dec 2, 2005 | 04:10 PM
cos jon's Avatar
cos jon
had all the front ones changed a few months ago, inner and outer CV and wheel bearings, defo coming from back left.!
Old Dec 7, 2005 | 09:28 AM
rs cos's Avatar
rs cos
DAMO WHATS A PROP SHAFT UJ? MINE IS MAKING SIMILAR NOISE SINCE I HAD GEARBOX CHANGED
Old Dec 7, 2005 | 06:07 PM
Dave Henshall's Avatar
Dave Henshall
Universal Joint, this bit that allows slight missalignment to be taken up without damage....
there are 2 at the fonrt and the most suseible one is the one at the fornt as it is right near teh down pipe and gets F hot, they come sealded lubed for life, but the heat baks then dry and they fook up, a good mod is to have a grease nipple fitted so that u can re grease it each time u drop teh oil
Old Dec 8, 2005 | 07:25 PM
Damo V's Avatar
Damo V
As per Dave,
But his pic shows a steering coupling
click this ... http://www.answers.com/main/ntquery?s=Universal+joint
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
DavidK
Sep 27, 2015 02:55 PM
