small turbo... boost question...
boost level
about 1.5bar boost from about 3000 - 5500rpm.
Suhe Motorsport piggy back ecu.
WRC head gasket.
Long stud and nut kit.
Uprated fuel pump. 3.5 - 4.0bar fuel pressure.
T28, 360 deg, checked every 250miles. (10 events).
Mongoose, only 1 box + HKS metal Kat, 3".
Plug gap 0.8mm
290ps
445Nm.
Sometimes suffer from Backfiring between gearchanges. should really fix this.
WRC head gasket.
Plug gap 0.8mm
290ps
445Nm.
cheers for all the replies lads mine is running a superchip plug in and was only boostin at 12psi.. turned it up to 16psi and it goes a lot better... will have to get it set up properly somewhere....
Thanks
Matt
Thanks
Matt
Take it to a tuner mate, set the boost slightly lower than 18psi, then when you take it to a respectable tuner they can fiddle with whatever settings they want and set the boost to the correct levels for you!
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
