FLAT BATTERY
Old Oct 26, 2005 | 07:30 PM
fordrallycar's Avatar
fordrallycar
Default FLAT BATTERY
HI ANY IDEAS WHY MY BATTERY IS GOING FLAT9AFTER 1 WEEK)
I HAVE CHECKED ALL THE NORMAL THINGS LIKE LIGHTS,CD PLAYER& ALARM I ALSO HAVE SPOKEN TO MY LOCAL FORD DEALER BUT STILL NO LUCK
PLEASE HELP CHEERS PAUL
Old Oct 26, 2005 | 07:33 PM
G1EN's Avatar
G1EN
could simply be dead cells in the battery,take the battery off and take it to halfords or most spares shops and get them to drop charge it, if the batterys fine then posiblt alternater not charging.
Old Oct 26, 2005 | 07:38 PM
fordrallycar
CHEERS MATE
BUT I FORGOT TO SEY ITS A NEW BATTERY AND THE GAUGE IS SHOWING ITS CHARGING AT 13 AMPS
CHEERS PAUL
Old Oct 26, 2005 | 07:39 PM
G1EN's Avatar
G1EN
is it turning over as if to start but no spark or are you just getting a loud click when you turn the key to start the engine?
Old Oct 26, 2005 | 07:40 PM
Damo V's Avatar
Damo V
Old tracker battery
Old Oct 26, 2005 | 07:41 PM
Damo V's Avatar
Damo V
sorry or boot light
What you gotta do is get an ohmeter inline on the earth side of battery and see what the current draw is, then remove each fuse 1 by 1 to see which circuit is drawing the current
Old Oct 26, 2005 | 07:43 PM
fordrallycar
JUST A CLICKING NOISE
WHAT IS A OLD TRACKER BATTERY???
CHEERS PAUL
Old Oct 26, 2005 | 07:44 PM
Simon Day's Avatar
Simon Day
Damo V's Avatar
Damo V
Some tracking devices have battery back up, as these batteries age they no longer gharge but drain
Old Oct 26, 2005 | 07:45 PM
G1EN's Avatar
G1EN
starter motor.........
had this on mine....went through everything to do with the battery, but wasnt. reckon i could garentee its the starter motor...
Old Oct 26, 2005 | 07:46 PM
Damo V's Avatar
Damo V
As per Glen do the heater blowers and lights work when you try to crank? what does voltmeter read when IGN on? could just be the starter
Old Oct 26, 2005 | 07:47 PM
G1EN's Avatar
G1EN
when mine went, it was reading 3 quaters on the gauge, but when u go to start it was dropping to half and just under, but if theres nothing there to start the engine then it wont start, hence why its not turning over.......
Old Oct 26, 2005 | 07:48 PM
Simon Day's Avatar
Simon Day
Side issue - my clifford has gone very, very quiet - is this the internal battery? - if so are they easy to change and where do I get one from?
Old Oct 26, 2005 | 07:49 PM
fordrallycar
I THOUGHT ABOUT THE STARTER MOTOR BUT IF I DISCONECT THE BATTERY AND LEAVE IT 4 A WEEK OR 2 AND RECONECT IT SHE STARTS 1ST TIME
CHEERS PAUL
Old Oct 26, 2005 | 07:50 PM
Damo V's Avatar
Damo V
tgsday
Needs a new siren /siren battery, I just put a new siren in mine myself but I know exactly how they fit and where my "brain" is
Old Oct 26, 2005 | 07:51 PM
G1EN's Avatar
G1EN
can you bump start the car......
i dont reccomend jump leads, as i used this method and it cooked my ECU.....
as i could get it started but would die near enuff straight away as it wasnt creating a constant connection from the starter motor...
Old Oct 26, 2005 | 07:53 PM
Simon Day's Avatar
Simon Day
Damo - how much do you think it will cost from a dealer?
Old Oct 26, 2005 | 07:55 PM
Damo V's Avatar
Damo V
suppply and fit no more than a ton I imagine , BUT they may just put a new battery in ... Mine made some wierd clicking noises sometimes too, thats also why I knocked it on the head
Old Oct 26, 2005 | 07:58 PM
Simon Day's Avatar
Simon Day
Old Nov 2, 2005 | 08:20 PM
G1EN's Avatar
G1EN
any updates on this as to the problem....?
Old Nov 2, 2005 | 10:55 PM
mk3cosworth's Avatar
mk3cosworth
no but mine is excactly the same lol
Old Nov 3, 2005 | 12:59 AM
S3an's Avatar
S3an
my battery was going flat all the time when i first bought my escos, turned out to be the fan sensor on the rad was faulty, switching them on unecessary when i left the car. just a suggestion
Old Nov 3, 2005 | 01:26 AM
Hydie's Avatar
Hydie
Old Nov 3, 2005 | 04:26 PM
salmon's Avatar
salmon
Mine did this and its the standard ford Immob (clicking etc), had that taken out, and never had any bother since. Also had the flat battery thing as well, and this was the boot light staying on when the boot was shut.
Old Nov 6, 2005 | 03:16 PM
Dave Henshall's Avatar
Dave Henshall
snap
the relay (large green one near the battery) was full of water and teh spring had rotted off iside, so it would pull in ok, but was pure luck the fans stopped(slow speed) when it deerergised
Old Nov 7, 2005 | 05:42 PM
cozzymatt's Avatar
cozzymatt
same as above...
Old Nov 18, 2005 | 09:14 AM
Redkop's Avatar
Redkop
This flat battery scenario seems to be a common thing... I have the same problem Have been putting a battery conditioner on it after every time I drive it. The battery is new too.
Old Nov 18, 2005 | 09:56 AM
Dave Henshall
even now, i cant leave it a week without it going partially flat, i have to leave it with an optimate on when im not using it, and thats with allt eh above probs sort, new tracker battery, fans, boot light, interior light etc etc, just dunno whats drawing the power
Old Nov 18, 2005 | 03:45 PM
Damo V's Avatar
Damo V
Easiest way to check what the prob is;;;;
Get a good ameter, remove -ve wires from battery bolt them together, then connect meter in series one end on batt other on wires, DO NOT start car etc..
you will se a draw figure (might be best to sit in car or remove door pin swtich)
it may be as high as 0.2 amps IIRC, till the inerior light relay cuts out after 20 secs or so it should drop quite a bit
I cant remember exactly what mine was, but I THINK it needs to be nearly as low as 0.020 amps
anyway whatever it is, in idle state, one by one remove each fuse in the fuse box/boot area, when you pull one and the current DROPS significantly, THAT is your problem circuit... I found mine to be an OLD tracker battery, which was no longer in use but still connnected!!
Old Nov 18, 2005 | 03:46 PM
Damo V's Avatar
Damo V
I should add its not uncommon for aftermarket H/Units to be the problem, apparently Kenwoods are renound for it
Old Nov 18, 2005 | 04:31 PM
mk3cosworth
kenwoods thats wots in mine, lol i might smash it up if its causing mine
ill have to do the amp meter test tomorrow
Old Nov 18, 2005 | 05:10 PM
Damo V's Avatar
Damo V
you have to put the meter on a particular way round, ie the red wire to batt black wire toe earth wires... BUT I cant remember which it was
Old Nov 18, 2005 | 06:59 PM
Dave Henshall
doesnt really matter which way round the ammeter goes, it will just read negative instead of positive,
will go through it all at weekend, as its got a new tracker battery, and ive pulled the interior light delay relay as thats faulty anyway
Old Nov 18, 2005 | 07:11 PM
Damo V's Avatar
Damo V
I thought my interior light relay was faulty also... IIRC it was like 40 quid but there was nthing wrong with it
Old Nov 18, 2005 | 07:16 PM
Dave Henshall
thats why i removed it and want to make sure it that before buying a new one, wunder whether if due to a low battery voltage, it makes it stick on..>?
Old Nov 18, 2005 | 07:20 PM
Damo V's Avatar
Damo V
I found with the relay removed, it confused my alarm into thinking I left the door open ... so just went and bought another
If I can find my old one do you want to borrow it?
Old Nov 19, 2005 | 08:12 AM
Redkop's Avatar
Redkop
I had a new interior light fitted as the old one was faulty. Taking my car down to Scotty in next 2 weeks - so will get him to check with ammeter for me. Could it be that the alternator is at fault, mine is orig one still?
Even when driving, SECs shows voltage at about 12.8 - 12.9 not ever into the 13s and if I switch engine off and just have ignition on, the voltage drops quite rapidly to 11.0 - 11.1
It all started when I didn't use the car for a month and battery went flat, then after being charged, I had all sorts of problems with the alarm going off 5 mins after being activated. I then got a new battery, reset the alarm but still goes off after 5 mins and none of the other faults have gone away
Old Nov 20, 2005 | 01:33 PM
Dave Henshall
right, u might find this interesting....
just gone through all my relays and fuses with an ammeter in series with the neg of the battery, car was pulling 120 ma all teh time and no unplugging of ecu,s alarms, tracker etc made any duifference,
un til i tried the yellow one on the back fothe fusebox, the one on its own, which until the other day i didnt know what it was for, it feeds the ford alarm box, whip it out, the red led comes on on the dash, but the battery drain goes from 120ma to 10ma.
fookin ford alarm, not the wipac imobilser, just teh one that stops it cranking if u lock the car with teh key in the door.
only problem now, my toad alarm locks the door when u lock it, but it also makes them deadlock , ok u think, but u have to disarm it twice now to get in, the forst disarm undoes the deadlocks, then the second unlocks the doors, put the gfuse back in and it all works as it shuold but he drain is back to 120 ma, so ive found what was pulling it down, just need to sort out getting it removed alltogether.
Old Nov 21, 2005 | 04:56 PM
Dave Henshall
wired stuff happens aswell with the ford onw powered down, if u slock teh doors while th engine is running, the oil pressure light comes on, if u lock teh door with the alarm, with teh engine running, u cant open them by the handle, u need to press the disarm button twice.
does anybody know what can fail to cause a battery drain of 100 ma in the ford alarm (the one in teh drivers kick well)
Old Nov 22, 2005 | 04:04 PM
Dave Henshall
right, got it sorted,
with it all plugged back in, with my ameter in place of the fuse on the back of the fusebox... with the doors unlocked, wither by the toad, or using the key in the door (or just by unlocking them from insode ) the ford alarm box draws a steady 100ma, as soon as you lock them (again by any means) this drops significantly to 8-10ma.
this would explain why leaving it unlocked and unarmed apartf from teh imobilser) it would flatten the battery enough to cause a dodgy start in a week, and almost completely in 2 weeks.
