700
hello!
guys, i need you experts big time!
my friend is gonna tune his escos to approx 700bhp, because we are a bit of a greenhorn, when comes to escos tune up, your help is priceless
please make a list what kinda tuning gods to put in, we shall do exactly as you guys recomend, this project depends on you!
THANK ALL!!!!!!!!!!!!!!!!!!!
cheers Simon, Europe
700? a bit of a steep aim when you confess to knowing not a lot about tuning an escos...
i wouldnt bother, get a ferrari or a porsche instead.. or an E46 m3 csl.. not the same league of power but a sweet car nontheless
700bhp will cost you over £40k
40k
u guys r jocking, right ?!
its gonna be for draging, brakes are already stroger, also shocks&springs
(eibach/bilstein), we are concentrating for engine and box only...
only smart advices, please
thx
thx
Go for a nice 500bhp which will cost between 12-15k if done properly, and add another load of cash for the gearbox/diffs
A nicely tuned 500bhp motor with the right set up will be as quick on the road as any Japcrap claiming 12000bhp
well money is not the problem here, i mean it is, but not the main issue
he's pretty loaded...
ok, let me say this way, he's looking for 8-9sec@quater mile, how much ponyes for this target?
If you don't know much about Cosworth engines, I think best choise for you and your friend could be to contact some know Cosworth expert and quote them for a price. 400bhp is easy and quite cheap, 500bhp costs a bit more and need some thinking and when you go beyond it things get much harder and the cost go way up.
Originally Posted by THE RADMAN
put it this way, John Tebenham's cosworth YB engine reached 7.7 seconds on a 1/4 mile drag race @ 170.5 miles an hours becoming the new world record for the fastest 4 cylinder YB cosorth engine
the engine is rebuilt to latest spec and produces a reliable 859BHP on Julian Godfrey Engineering Superflow Dyno.
i wouldnt expect much change from £60k!
that is smart ADVICE
I paid 5K+ for 375Brake
New block and longstudding 1k ish???? plus bore machining?
New pistons PLUS machining to low comp and valve cutouts 300 ish
turbo rebuild 350ish (for 400 plus you would ideally go bigger than std so dont expect much change from 8-900£)
big wing baffled and windage tray sump 300ish
minor head work 200ish (plus lifters)
STD cams (New ones for 400+)
New injectors 200ish?
Live map on Dyno 7-800ish
pectel board/chip 250ish
Gasket set
WRC HG 400ish
OIL pump 150ish
cant remember what else, though obviously some labour
On top of that I bought
new clutch fuel rail fuel reg pectel wiring loomblah blahh blah loads of stuff which came in at a further 3-4k... And I kept it sensible
Gasket set
WRC HG 400ish
OIL pump 150ish
I'm not picking a fight, I just don't understand where you spend all your money
I know one Escort Cosworth from Finland that has 9:1 compression and it has more than 600bhp, so I don't see any point for going low compression. You just need to use more boost and you get even more lag than with normall/higher compression. People we are not in the 80's anymore
because my engine builder specced it for me, I just paid him
The brief was "A SAFE strong reliable 350+" SAFE and RELIABLE were the key aspects for me
That'll be the same engine builder who builds MANY High comp rally engines.. you may have heard of him, Harvey Gibbs
you dont even want to know what condition my old engine was in before I went to him
if your after big power, this guy will tell you what you need
http://www.racetuners.com/html/julia...ering__hi.html
When i had my engine rebuilt i went low comp too for the simple reason that if i ever came across a propely specd head then the bottom end was already done. Its also far safer if your running big boost.
for 700bhp.....you need at least nikasil liners..which cost for an extra 1300 pounds fitted to the block....
you need a gt40 turbo....well something bigger then a gt35....a lot of revs for a 2 litre....or go for a stroker engine...
maybe you should ask martin hadland what will cost for 700bhp....he is building such an engine right now...and believe me...its expensive...
if you have to ask all these questions maybe its better to let someone build it for you...
Does your mate want a 8 second car for competition or for fun?
If you want it for fun I would suggest an engine something like this
Low comp 7:2:1, T4, l&b bottom end, ported head, cams etc touring car spec with 100 shot of nos. Kev sharp ran 10.3 on a car of a similar engine spec on a road car not stripped out. If its going to be a drag car then it will be stripped out. So if you get a well built engine to above spec stripped out interior really good gearbox and diffs and slicks then you will easily manage a nine.
Concentrate on the gearbox/suspension/weight setup remeber power is nothing without control.
TPM961
15-01-2018 10:50 AM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
