what oil do you use for your es cos pls?
Just playing "devils advocate" here really.
Why are people using 10w-60?
The recommended oil for the Escort RS Cosworth is 5w-40 or 10w-40.
What this actually means is that this engine is happy on an oil that has a viscosity of 14cst at 100degC which is an sae 40 not an sae 60!
An sae 60 is in fact 24cst at 100degC which is a whopping 70%+ thicker than required. This is not a good thing so let's not be macho about it.
An oil that is too thick will cause additional friction, heat and engine wear added to which it will reduce your fuel consumption and BHP at the wheels!
An oil that is too thick can also cause cavitation in the pump!
Now, ok I accept that in extreme circumstances (Rod Tarrys Cosworth as an example) there may be an argument to use an sae 60 as the mods are extreme to say the least but on most of your cars it's causing more harm than good.
Mods that affect BHP and particularly oil temps may need a step up to an sae 50 (18.5cst at 100degC) but this is only applicable if your oil temps exceed 120 degC!! This will prevent the oil from thinning too much at these extreme temperatures and above.
Don't step up viscosity (oil thickness) unless it's totally necessary, step up the quality! A proper synthetic 5w-40 will handle 120degC an that's a fact.
Just concerned at the inapropriate use of 10w-60
Simon
Simon
Indeed I have and I'd love to know the reasoning behind the 10w-60 recommendation as it's a long way "out of grade".
Sorry the "macho" comment wasn't meant to offend anyone, just my twisted humour I'm afraid
Simon
Simon
I would recommend a decent 5w-40 or 10w-40 synthetic.
Silkolene PRO S 5w-40
Motul 8100 5w-40
Motul 300V 5w-40 or 10w-40
Fuchs Titan Supersyn SL 5w-40
These are all proper synthetic oils, no petroleum basestocks.
Email me for a price list, you'll be pleasantly surprised!
sales@opieoils.co.uk
Simon
Motul 8100 5w-40
Simon
Originally Posted by Franco
Simon,
Quick question........Why did you recommend to me using Pro S 10w - 50???
Sorry alittle confused when you quote 5w-40 or 10w-40.
Thanks
Jason
Thanks
Jason
If the car is modded or used on track we tend to recommend the PRO S 10w-50 instead of the 5w-40 as it will take higher heat than the 5w-40.
At the end of the day, both are interchangeable as they are both good on cold start and extremely thermally stable due to the ester/pao basestocks used.
Your engine would be happy on either and it's down to personal choice.
Simon
Simon
Originally Posted by scruffythefirst
Why do you reccomend running a cossie in on 15w - 50 when a 5w - 40 or 10w - 50 is reccomended for normal use?
then after the 500 or so miles running in you'll change over to the good stuff!
Its castrol RS 10/60 in mine, used the mobil 1 motorsport 15/50 and after one track session it was really thin and standard oil pressure gauge was sitting just on the red at idle.
If you are using 10w-60 then I would highly recommend that you try Silkolene PRO S 10w-50 next time around.
This oil has been tried by many tuners here with noticeable positive results.
You've nothing to lose by switching from a petroleum based oil to a proper synthetic but plenty to gain if the car is modded or used on track
Simon
Simon
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
