OZ centre caps
i also tried getting a set with no luck in the end i sprayed them 2 match the oz writing on the wheels not 2 everybodies taste but better than corroded centre caps
I HAVE FOUND A PLACE THAT SUPPLIES THEM NOW,I'M WAITING FOR A PRICE..I'M ALSO GONNA ORDER A SET FROM THE NEW SUPERT T'S GT AS WELL, AS THERE IN CARBON FIBRE....IF THIS PLACE DOES GET THEM I WILL LET YOU ALL KNOW.
i ordered a set today, i chose the new type that are carbon fibre as the old ones just corode after a while.The guy from the shop said they all do it after a while, probably why OZ use carbon fibre ones now? Anyway they're Ł12.99 each and he has them in stock, he can order the originals in if you want,but i think its a waste of money you spend Ł50 and they will be like your originals after a while.This is the link for the shop,although you will have to order by phone as the centre caps are not in the online shop.
Link www.PerformanceAlloys.com
Contact info:
TEL: +44 (0)28 9446 5151
FAX: +44 (0)28 9446 2121
Contact info:
also try wheelworx in mansfield.. very helpful guys and can get either standard ones or the carbon ones personnally i found the wheels looked smaller with the darker centre caps
07-10-2015 12:56 PM
