help needed!!!
Old Feb 8, 2005 | 07:52 PM
jamesXXX's Avatar
jamesXXX
Default help needed!!!
fitted a set of gaz coilovers at the weekend, but now i have a loud knocking noise coming from the offside rear of the car when i go over moderatley bumpy roads, its not the coilover unit catching, there seems to be a bit of play in the swing arm bush, could this be the problem, and if so, are the bushes of the press in type??
fookin cars
Old Feb 9, 2005 | 09:06 AM
Glenn5's Avatar
Glenn5
i know your suppose bash the inner rear arch out 2 allow full movement, didnt you have too do that, as 4 the bushes cut em out and push in new 1s there in 2 pieces and go in from either side.
Old Feb 9, 2005 | 10:36 AM
Dave Henshall's Avatar
Dave Henshall
yep as above - you cant just fit coilovers with no arch mods as there is not enough room up the std strut turret to allow for the spring without opening it up and reinforcing the top.
Old Feb 9, 2005 | 08:30 PM
jamesXXX's Avatar
jamesXXX
ive opened up the area behind the coilovers when i fitted them, but it sounds like the noise is coming from underneath, so ive ordered new bushes, il see if that helps..
Old Feb 11, 2005 | 07:46 AM
cossymad's Avatar
cossymad
Sounds like bushes. Give us a call if you get stuck after that
Old Feb 11, 2005 | 01:38 PM
ESCYSCOTT's Avatar
ESCYSCOTT
so do coilovers not just bolt straight on then?? I was wanting some for mine but i dont wanna be hammering the inner arch to make them fit as my car is a concours car with painted inner arches etc.........
Old Feb 11, 2005 | 01:43 PM
cossymad's Avatar
cossymad
They do other than the inner rear arch on nearside. It's so close, it rubs on ALL escorts when putting the larger diameter springs.
It's easy enough to do though, with minimal damage.
Use a sponge hammer. It'll take longer, but be safer
Old Feb 11, 2005 | 03:32 PM
Glenn5's Avatar
Glenn5
ive trial fitted mine it rubs the paint more than any thing a bit of carefull tapping with a rubber headed mallet and cloth mint m8, looks factory still as the stonechip disguises the panel appearance anyway.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
