mt 75 gearbox
MG Maestro turbo 437
mt 75 gearbox
my cosworth has very small whine in 4th and 5 th gear i have decided to change gearbox there a few on ebay, just simple question all they all the same? all 4x4 gearboxes.
this is the one i bought for only £52!! but is it the correct one?
Peter
Peter
no they are not all the same, they look it but they are not. The clutch piviot pin is different in a DOHC, the ratios are different and the output shaft might be different there are two types.
itl fit mate,just change the pivot pin and fork from ur old box over and the gearstick cradle and then use the 3 long threaded bolts from ur own rear output flange and il be find ,ratios will be differeny but shudnt be enough to cause harm
oppliger ENGINE & GEARBOX....
first road test of our powerful Cosworth car....1.6 bar of boost....we have to finish the map for 2.2bar...
engine spec:Nikasil liners on 200 block,10 long studs,Arrow cranckshafts,Arrow rods,forged pistons,ported head,double valve springs,Nimonic valves,solid followers,wild camshafts,wrc 8 injectors manifold,swedish plenum,70mm body,tubolar exhaust manifold,gt35 turbo,external wastegate,coil pack,pectel super 8,twin 044 fuel pumps,etc....ops....Oppliger BIG TOOTH GEARKIT
videos:
http://www.youtube.com/watch?v=wlwjhSHrJiA&feature=response_watch
http://www.youtube.com/watch?v=HZwbfVGnaw4&feature=response_watch
videos:
The rear output flange can differ too. There are two types, one takes the early thick rubber donut, the other takes the thin later type donut. You need the matching donut and front section of the rear prop for everything to match up nicely
chowfornow
14
05-01-2019 09:01 PM
