escort cossy engines
im buying a escosy ive got about £15000 to spend.........
only i wos just wondering? wots the diffrents between the 2 engines e.g flat top and the ovrel one... and wots most relibale and best to tune.... ps wot boost do thay run standard and wot is a safe boost i can run after i fit a s/s zorst........... if any one can help that is thank you.........
Big turbo engine is cheaper to tune and 330bhp is just a few bolt ons away. The small turbo engine is strangled by its Ford EECIV ECU and small turbo but if you are prepared to get the chequebook out and replace the ECU/turbo the small turbo engine is the best base engine for a power build.
Std they run .9bar boost with 1.2 bar overboost.
Cam
PS, a spellchecker wouldn't be a bad idea!
Cam
