Holy smokes! Help!
Old Aug 27, 2008 | 05:58 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Default Holy smokes! Help!
The car hasn't been very healty as some might know from one of my previous Threads. Car has stood for well over a week without running. Yesterday I couldn't even start it. So today I removed the multiplugs and soldered the wires. I also cleaned the plug to the lambdasensor and checked the plugs (what gap should I run? No mods to the engine..) took the lead off the battery for about half an hour to reset the ecu (if possible on the P8?)
The car fired straight up. Tickover just below 1k.
And NOW!! White smoke on tickover, and loads more when I give it some throttle. I didn't notice anything before. It hasn't been running atleast for the past week..
Thoughts?
Old Aug 27, 2008 | 06:20 PM
JHS's Avatar
JHS
Have run it proper warm then? I bet it stops when it gets warm...
Old Aug 27, 2008 | 06:29 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Venta egentli på svar fra deg haha.. Gonna try a testrun with it and see if it cures it.
Old Aug 27, 2008 | 07:08 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Well now it's fine actually. That's a relief. But it it didn't cure the original problems. Comes on boost and cuts out on 4k in every gear. Even when given light throttle i.e no boost. And the oilpressure gauge has got a short somewhere now. peaks when ignition is on.
Old Aug 27, 2008 | 07:28 PM
RoyP's Avatar
RoyP
try the amal valve, lambda sensor, and so on, even beter get a read out of all the electrics, its running in safety mode
Old Aug 27, 2008 | 08:15 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
ordered a bunch of sensors. going to try one after the other..
Old Aug 28, 2008 | 04:31 AM
stevecossy's Avatar
stevecossy
Hi maybe worth changing the fuel filter and checking the pressure.
Is it a small or large turbo engine? Also worth checking the timing and poss of dissy etc, try the plugs at about 0.7mm.
Good luck steve.
Old Aug 28, 2008 | 10:46 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
large turbo. getting some parts from msd soon so I'll wait until then.
Old Aug 28, 2008 | 12:22 PM
Dave Henshall's Avatar
Dave Henshall
the 4K rev limit means it IS in limp mode, and will return once the faulty sensor or fixed.
if it starts and runs but in limp it can only be 3 or 4 sensors, coolant temp, charge temp or lambda, if it were crank or phase, it wouldn't start.
the white smoke will have been steam, if the car had been warm then left outside in the cold it will have condensed a lot of water vapour in the exhaust - nothing to worry about.
Old Aug 28, 2008 | 01:04 PM
AlexD's Avatar
AlexD
Post Miester !
I reckon its a Faulty ACT Sensor poss..
Old Aug 28, 2008 | 07:07 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Thanks guys. Really appreciate it Got them on order now so we'll see.
Old Sep 8, 2008 | 03:40 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Changed the act. it looked really bad actually.. but no difference. Do I have to reset the ecu after fitting the new sensor? Might boil down to lambda this i suppose.. doh..
Old Sep 8, 2008 | 03:51 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
if it helps, the car is ok for a short while when it's cold.
Old Sep 9, 2008 | 07:15 AM
JHS's Avatar
JHS
So have you changed the blue water temp sensor as well?
Old Sep 9, 2008 | 02:01 PM
Stu @ M Developments's Avatar
PassionFords Creator
I would be looking at the lambda signal or phase sensor personally.
Old Sep 9, 2008 | 06:26 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
so the car can start even if the phase sensor is knackered? Can I measure the lambda in an easy way? Voltage output maybe?
Old Sep 9, 2008 | 06:59 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
no difference with a new coolant sensor btw. gonna try phase tomorrow. guess there is only those two left now.
Old Sep 9, 2008 | 07:00 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
the lambda looks very grey and rattles when shaken btw.. I'm no lambda expert but I guess that isn't good.
Old Sep 10, 2008 | 02:50 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
wasn't the phase sensor either. New lambda then..
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
