HELP With CPS
Old 06-06-2008, 11:23 PM
llw
llw's Avatar
Default HELP With CPS
Right i am changing the cps sensor tomorrow due starting problems on my ST Escos
Can anyone tell me how to do this, as i dont have a clue
thanks in advance
Old 07-06-2008, 06:10 AM
Get car on ramps, locate the CPS at front of engine at about the 7 o'clock posytion around the crank pulley, reach up and undo connector, take out two small(8mm) bolts that hold sensor to bracket on front of sump, reverse for new one.
Make sure gap is 0.6mm - 1.0mm between sensor and a lug on crank pulley, reconnect job done.
Old 07-06-2008, 01:12 PM
llw
llw's Avatar
right i have got the whole bracket off
but sensor wont come out of bracket
any ideas
and its about to rain
Old 07-06-2008, 01:35 PM
THE RADMAN
THE RADMAN's Avatar
on the small t its just a push fit inside the bracket
Old 07-06-2008, 01:38 PM
THE RADMAN
THE RADMAN's Avatar
should look like this
Old 07-06-2008, 02:59 PM
llw
llw's Avatar
thanks sensor is on now
one thing i did realise though was when i started it, there seemed to be like a knocking noise under the cambelt cover
any thoughts anyone
DixieTheKid
11
06-06-2020 11:20 AM
biggiejody
19-09-2015 10:25 AM
wheelwizardrefurbs
18-09-2015 08:59 PM
marky_g
17-08-2015 12:21 PM
lockie
31-07-2015 10:03 PM
Quick Reply: HELP With CPS
