converting st escos too large. whats needed??
could anyone post a list or a how too on converting a small turbo escort cosworth too a large. inc parts needed and all other info?
cheers guys
cheers guys
depends on wether you want to use after-market managment or the system off a big turbo car. Most people use the big turbo stuff, in which case you will need,
ecu, engine loom, map sensor, coil, leads, dizzy, plugs, turbo, manifold etc....
prob b easier to use the loom off the lager escort i would of guessed? are the sensor is in and around the engine different to the large turbo? of will the loom form the large turbo plug straight in the the small turbo sensors?
If you are not in a mega rush, there will soon hopefully be a new conversion on offer by MSD, all you have to swap is the turbo (T34.48)and the exhaust manifold to big turbo/ 4x4 saff spec, and a few other minor parts, and then it will be able to run 350 BHP on the std ECU
My engine build is starting next week so hopefully once Stu is back from honeymoon he can finalize the conversion
yeah that sounds like a plan, id be happy with arount 350, if i could get it there without doing the loom and dissy thing that would be good
Injectors.
Fuel Pump.
Plugs.
Manifold.
T34.48
Chip.
Actuator.
my st escos has low comps, 305 ggr chic, uprated fuel pump, t28 hybrid (what exact spec i dont kno0, carried out by ggr, all work done by previous owner, must be around 300bhp mark, but wanna get another 30 -- 50 bhp, if i can
From: brum/shropshire drives:- frst / escort cossie
depends on what management you wanna use i run autronic SM4 tbh the best mod i had so far, mine now runs a T34.48 and i'm running 390hp,430lbft on high boost drives great and features of the SM4 are cool... cost me a few k BUT its one of the best systems available... with your spec you may make more power than me running what i run . then there pectel or LT management but i think to gain the best you need aftermarket management...
Dont really understand why people do this, when they can jsut go out a buy a large turbo model.
theres bugger all difference in the actual car and less hassle with getting everything changed over.
Why do people go to so much hassle when its not needed.
Also, if this new conversion MSD are working on comes good ( and its 95% there ), you will have all the benefits of the ST models standard features such as adaptive fuelling, and coil packs as std, and it is a VERY capable ECU, don't let what you have seen written by very un-knowlegeable people make you think otherwise
Originally Posted by kennyA
Hi Adamski frst
thats an impressive torque figure. Do you have a printout of the torque curve?
cheers
kenny
cheers
kenny
Stupid conversion! Use the inlet you`ve already got, as its better. Some sort of aftermarket quality management system like LINK og Autronic. Get a new GT series turbo and a intercooler, job done! we have done this to two ST cars lately and works perfectly and goes well even with standard engines.
the managment system (the loom and ecu) does the loom off the larger turbo models plug directly in too the same sensors on the engine of the st escorts, or do the sensors have to be changed too?
the changeing turbos and intercooler fitting i can do to my car no probs but the loom and ecu upgrading im not too sure about as i have never really done ne thing with the electrical side of tuning with cars.
please dont consider changing to a standard BT original loom, as it old an prone to fail, yours is newer and better, would be a big downgrade, just as changing to an old standard garret t35.. Use a new management, and get a pro to set i up for you with a proper turbo and intercooler, you will never look back. here is some pretty cool products at not to bad prices www.linkecu.com
still gotta say altho mine cost alot i had a ryan loom along with the autronic, the wiring has and will never let me down my car can only get bigger and better with whats been fitted ... fit autronic and you'll never look back
waiting for parts is the bug-bear of my life , I wanted to get the engine in and out in 2 weeks, but due to seriously upgrading everything, it has taken since april to be ready to put the thing back together I sold my old quaife gearbox to a guy in Poland who took 5 weeks to pay me, then my new box took 2 weeks to build, then the block and headwork took 3 weeks, lightening and balancing has taken 2 weeks, it all adds up, I can't really complain about turnround time of companies as they all are busy, but you get stuck waiting for parts that mean you can't do anything else until you get them. Of course cashflow has been a bit of a problem as well seeing as the 4x4 running gear upgrades have cost £5400 on their own , thats before 2k of engine parts, all the machining, £1500 for brakes, blah blah blah It is amazing how fast all the "little" parts add up .... Good thing is the car will be 95% brand new on the mechanical side of things
I will take a picture of all the parts that I have got ready to fit, it will be like that group A photo on the front of the book
Here is the brief spec
Spec- (and why it's taken so long to rebuild, it's having a top to bottom overhaul )
Car started out as a 96' N Plate Small turbo, with a 280BHP MSD chip. Then I bolted the T34 onto a std car for Stu's experiment, and the rest of the car was pretty Std bar a Mongoose/ konis etc.
How it is Now/ going to be in a few weeks time:
Engine:
7.4:1 cc'd
WRC long studded decked T25 200 block
0.5 over size Mahle low comp pistons with Valve cut outs
Lightened and Balanced bottom end, ARP bolts throughout.
High pressure oil pump with std T 25 WRC oil spray jets
Big wing gated sump
Cometic 3 layer steel Head gasket
Ported and Polished/ cc'd chambers head 25/26mm ports
New valve guides+ re-cut seats, skimmed flat for metal head gasket
New O.E followers, Std Exhaust cam Brand new from Blank BD14 inlet cam
Vernier pulleys
Every bush gasket and seal replaced with cometic or new item
New water pump
C.R Engineering T38 To MSD specifications
Big turbo/ sapphire 4x4 exhaust manifold (larger collector port)
Injectors- TBC, but currently 55Lbs siemens
Black silicon hoses throughout the engine bay with a re-circulating Dump valve
Collins engine mounts+ gearbox mount
Full Mongoose Stainless steel exhaust
Bosch 023 intank fuel pump
Provisional- Pro Alloy/ R&B development uprated intercooler to retain air conditioning yet massivly improve ACT's ( Car going to Pro Alloy as soon as its ready!)
Spec R header tank with sight glass
Baily 3 port breather
Alloy P.A.S tank
MSD Mapped EEC IV ECU
Drivetrain:
Ford motorsport genuine 909 thickwall front differential with std ratio open diff, Steel sandwich strenthening plate. ( may upgrade to R&B alloy plate)
Bara Motorsport "mullit" fully straight cut MT 75 gearbox with uprated 1st gear and std ratios.
2wd Std Cosworth rear beam ( to be upgraded to Zoo or equivilant when funds allow )with 7.5" Std 2wd Cosworth LSD. 2wd driveshafts.
Reyland twin plate organic clutch with centre push hydrulic conversion
Chassis
18" Rondell 122's with 225 40 R18's with Goodyear Eagle F1's
AP 362x32mm 12 Groove brakes with 6 pot (7040) callipers.
Std Rear Brakes
Braided brake lines
Every suspension bush replaced with Polyeurothene (powerflex)
Front and rear Group A Strut braces
Adjustable TCA's
Bilstien 909 soft tarmac front coilovers (spring rates TBC)
Bilstien 909 Magnesium medium gravel rear coilovers (spring rates TBC)
Std ARB's front and rear
R&B rear toe shim kit
General
Crystal Morrettes (maybe std lights, not sure yet )
Autometer 63mm ultralite -30/+30 A pillar mounted Boost gauge
52mm Auto Meter ultralite oil temp gauge
R&B ACT gauge
Std lux leather interior retaining air conditioning.
Vanillarama yellow magic tree (+15BHP across the range)
Hence my wallet is going "ouch"
BIG THANKS TO: Ian@Racetek , STU@MSD, Matt Lewis Motorsport, Mike Rainbird (R&B), Martin Hadland (Reyland), and my mates who have helped me no end Jamie Lawley (J.Lawley Garages), Big Ste (4x4 ste), Ginger Yates(Altratz), Si Leadbetter (Melzieanne) , Neil (Boost Happy) and everyone else that has taken the piss, helped, laughed at me etc etc
Won't be long now
Can't wait to get it back to MSD for them to play with it
Full thread on tuning the small turbo Escort
https://passionford.com/forum/viewto...er=asc&start=0
Engine:
7.4:1 cc'd
Big wing gated sump
Vernier pulleys
New water pump
Alloy P.A.S tank
Drivetrain:
Chassis
Std Rear Brakes
Braided brake lines
Adjustable TCA's
General
R&B ACT gauge
Won't be long now
jessie_rs
11
03-06-2019 04:57 PM
james kiely
28-08-2015 08:58 PM
