Metal Rad pipe....
Metal Rad pipe....
Hi Guys, don't supose that anyone knows where I could get one of these modded with a quip fitting on the end?
I've got one at the moment with a quip fitting that I bought off of Dave, but I want to move the water piping around slightly as with it in the standard poisition i'm not happy with how the swirl pot hoses sit...
i binned mine as they rust like mad and renewed the lot in aeroquip,just need a small piece of 15mm copper to join it to the other hose that runs to w/pump at the other end
Had another idea.. - does anyone know if the speedflow 999-10s will be a steel weld on fitting - looks like it will be, but want to check before ordering..- I can then order the metal lower rad pipe from fusion / AS, and get this fitted to help tidy up the front end a little!
