Best way to modify spring platform on Konis
For extra clearance when fitting bigger/wider wheels
any pics please guys, can they be cut (like an RS500 battery tray)
I am doing mine this weekend and welcome your suggestions
i had some that ggr had done once and they just used an angle grinder to cut off the lower part at 45 degree angle then welded a flat piece of steel on to fill the hole, it depends on how much modding is reqd
Originally Posted by RWD_cossie_wil
just chamfer them with an angle grinder like the pic above I did exactly the same with mine 225-40R18s on Rondells
to get them to clear with space
Originally Posted by MONSTER
I used a 5mm spacer Mat. let me know if you need some as i've a spare pair
SMILER258
28-09-2015 09:04 AM
truffleshuffle
10-09-2015 09:35 PM
