escort cossy t28 what power
what maximum power can I expect from this unit...
I have modified it with a larger compressor wheel and 360 thrust
Only I am getting boost drop off it will go to 20psi+ but drops to 15-16psi around 290-300bhp
thanks for any advise
cheers
Scott
cheers
Scott
From: brum/shropshire drives:- frst / escort cossie
you need to make sure the car is setup/chipped also with a uprated fuel pump and exhaust system to see anything near 300bhp ....
i was running 1.2bar with the above and a hybrid turbo and got 298bhp-320lbft..
but i run autronic management now.
yep fueling is fine, touch rich around 11-11.5afr
it made 290bhp last time on the rollers, but I have had 307bhp best
exhaust is 2 1/2" single box, forgot to mention its not on a escort (its a rover tomcat)
I am hoping if I can get it to hold 20psi to see 320+bhp
Has anybody made much more power than this with this turbo?
Just wanting to discount it as to why my boost is dropping.
Only if I run 16psi it holds rock steady
cheers
Scott
