Plug gaps
Old Jan 26, 2007 | 12:09 PM
Gary F's Avatar
Gary F
Default Plug gaps
Can someone tell me what gap I need on a set of motorcraft plugs on a stage 3 Escos?
Old Jan 27, 2007 | 07:31 AM
Gary F's Avatar
Gary F
Anyone
Old Jan 27, 2007 | 01:29 PM
G1EN's Avatar
G1EN
standard it would be:
LT 0.8
ST 1.0
dont know if they would change for bigger power, wouldnt thinks so.
Old Jan 27, 2007 | 02:06 PM
rsdene's Avatar
rsdene
i run a 0.5 to 0.6 gap mate,
Old Jan 28, 2007 | 12:50 AM
Arnie's Avatar
Arnie
GGR recommends setting it to 0.70 mm
Old Jan 28, 2007 | 09:47 AM
rsdene's Avatar
rsdene
well i have group a coil and 909 leads and i just get a miss fire above 0.6
Old Jan 28, 2007 | 10:55 AM
Arnie's Avatar
Arnie
u using group a coil and still can't increase the gap? I'm just using the normal coil and I set mine to 0.7mm and everything is sweet, but I'm using champion's racing plugs
Old Jan 28, 2007 | 11:03 AM
THE RADMAN's Avatar
THE RADMAN
i run 23psi and gp a coil, and im running .85mm,better idle quality too
Old Jan 28, 2007 | 11:14 AM
Arnie's Avatar
Arnie
thinking of either do a coil pack conversion or just replacing the coil with a group a item (a lot cheaper). any benefits in using the group a coil? how come it is cheaper than the standard coil? anyone know?
Old Jan 28, 2007 | 11:17 AM
Dave Henshall's Avatar
Dave Henshall
go coilpack - you will never have a missfire again !!
Old Jan 28, 2007 | 11:54 AM
Arnie's Avatar
Arnie
400quid and 40quid, which one do u think the missus is going to pick? we are not talking about handbags!
Old Jan 28, 2007 | 01:00 PM
THE RADMAN's Avatar
THE RADMAN
lol,i paid £25 for mine,brand new,good old ebay,lol
Old Jan 28, 2007 | 01:43 PM
£32 delivered from MATT LEWIS 01922 692424.
Plug gaps will defo have to be made smaller if running seriously increased boost, IF it starts to BLOW SPARK OUT, ie prevent it from sparking the HIGHER the PRESSURE in the cylinder, ie BOOST or CR the higher the voltage needed to jump gap at plug.
Old Jan 28, 2007 | 01:52 PM
Arnie's Avatar
Arnie
bearing in mind that I actually live on the other side of the Earth, I don't think Matt can do £32 delivered, if he can, I'll take one right now
Old Jan 29, 2007 | 07:38 AM
Sorry did not realise you lived somewhere sunny, not used to sun living here!!
Old Jan 31, 2007 | 08:21 PM
Stoo's Avatar
Stoo
I just changed my plugs and the car drives spot on untill you bring in full boost then it missfires like a pig..
Make the gap smaller then?
Old Feb 1, 2007 | 06:19 AM
Gary F's Avatar
Gary F
I've set mine to 0.7 and there spot on
Old Feb 1, 2007 | 06:27 AM
When my car had(new) 909 leads it missfired under load with standard coil at 0.6mm, change leads to MAGNECOR missfire went away, now got group A coil so going to gap larger.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
