Water leak
Water leak
Hi can any1 tell me if the water pumps gone or something else cos my cars leaking from around the metal pipes at the front of the engine where the 2 coolent pipes fit on its also bubbling over from the header tank any help would be great
it does sound possible that the water pump has gone.
the water inside the engine is getting too hot and not moving arund,hence the bubbling from the tank and the leaking pipes,just the pressure inside the engine.
have you a swirl pot on your car......can you see the water moving around etc.....
Mark RS
12-10-2015 06:01 AM
