Map Sensor
Old Oct 13, 2006 | 05:22 PM
bpspa's Avatar
bpspa
Default Map Sensor
I have been told today that I need a new map sensor, I am unsure on the different types as I have seen ones that are 2 bar and 3 bar. Can anyone explain and when should the different ones be used?
for info my car has been chipped
Old Oct 13, 2006 | 05:59 PM
tim10_10's Avatar
tim10_10
Well depends what chip you have im sure the large turbo runs a 2.5 bar standard may be 2 bar but the small turbo is a different one altogether. You only need three bar on dark greens or above.
Old Oct 13, 2006 | 06:00 PM
dave cos4x4's Avatar
dave cos4x4
standard cars use 2 bar map sensors, chipped cars on green injectors use a 3 bar map.
what power is yours running.
better to have a look at your old map sensor to see what one it is.
Old Oct 13, 2006 | 06:21 PM
Kelv's Avatar
Kelv
Almost there!
Dave, im pretty convinced the escort cossies are 2.5bar standard, 2 bar was the 3dr cossies and saphs etc.
Old Oct 13, 2006 | 07:33 PM
bpspa's Avatar
bpspa
its a small turbo, running around 250 - 270bhp, haven't had it on a rolling road so don't really no for definate.
will have a look at the old one. Can anyone recommend a place to get a new one from as I think Ford no longer do them.
cheers for the help
Old Oct 13, 2006 | 07:42 PM
Kelv's Avatar
Kelv
Almost there!
if it is a 3bar map sensor that you will need then i have my one which i just removed from my car thats for sale.
it all works fine, just removed as my new management uses its own map sensor!
£30.
Old Oct 13, 2006 | 07:57 PM
Dave Henshall's Avatar
Dave Henshall
if its a small turbo as you say,
its not the ones as used on the other cossies and is a different animal altogether
Old Oct 13, 2006 | 08:48 PM
dave cos4x4
Kelv, yes i think you are right.
As Dave said,
dont the late cars run different management...do they have map sensors.
different to the big turbo management so a 2.5 or 3 bar will be of no use.
Old Oct 13, 2006 | 09:45 PM
bpspa's Avatar
bpspa
what are the advantages of changing the management system?
can you do it to a small turbo?
Old Oct 13, 2006 | 10:03 PM
tim10_10's Avatar
tim10_10
Yes you can do it to a small turbo. The advantages on a small turbo is that you will have a fully mappable engine management system, therefore being able to alter fuel and ignition settings etc.
Old Oct 13, 2006 | 10:05 PM
dave cos4x4
When you want to change from small turbo to big turbo, for power improvements.....you need the weber marelli management and all the relevent bits to go with it.
there are other management systes around but i'm not clued up on these.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
