Part number finis help
07-10-2006 | 10:38 PM
I cannot for the life of me find the finis for the clips that hold the header tank to turbo pipe onto the inner side of the slam panel
can someone help please
08-10-2006 | 05:38 AM
I want one too
08-10-2006 | 07:33 AM
i bought one a few months ago and the number on the packet it arrived is F1651304.
hope this helps, by the way how many clips should be present to hold this pipe to the slam panel
08-10-2006 | 10:21 AM
Cheers matey I'll check that number out
I believe there are two of these clips
08-10-2006 | 03:54 PM
From: brum/shropshire drives:- frst / escort cossie
i have 1 on mine but there should be 2 i think they just get brittle over time and snap
08-10-2006 | 04:06 PM
if there is supposed to be 2 then, the clip that I have does not fit in any predrilled holes on my slam panel (the clip does fit the hose).
I couldn't test its fit where the other clip is as that wouldn't come out and I didn't fancy snapping it.
08-10-2006 | 08:57 PM
if i remember correctly there is only one fitted from factory,but im sure there is a spare hole,although its a diff size,i had a job finding that one myself
08-10-2006 | 11:24 PM
i want some too, mine has cable ties
09-10-2006 | 06:42 PM
Radman, have you got two clips on yours then?
Paul any luck with the code, and are you after a second clip or the original clip?
Ben
09-10-2006 | 06:56 PM
one clip but two holes, the second has a black plastic blank in it
10-10-2006 | 09:03 PM
Two clips, check the picture
11-10-2006 | 06:18 AM
one clip and one strips
11-10-2006 | 07:23 PM
Quote:
Isnt the clip on the right the bonnet stay clip??
11-10-2006 | 07:29 PM
Quote:
same as mine and mine is defo factory
11-10-2006 | 08:19 PM
Sorry for delay been away, yes the part number is correct
12-10-2006 | 12:24 PM
tryed too put a new in the other hole - but F1651304 -part nr dont fitt - hole too big - but fitted perfekt in orgnal place
12-10-2006 | 12:34 PM
12-10-2006 | 04:11 PM
it does fit in the other hole which is too big, you need to spread back of clip hold in position in the hole and put a cable tie around the back of it job done looks factory
12-10-2006 | 07:10 PM
Quote:
tryed that ?
in my car the beam in not too get into from the back or under ..........
12-10-2006 | 11:36 PM
i got 4 today, 50p each
13-10-2006 | 08:15 PM
Look "behind" the bonnet stay clip
I used to have one there, but it broke when I changed headgasket and had most the parts off...
There is 2 clips, the others are obviously missing one!
14-10-2006 | 04:36 AM
soory JHS my esc is standar all the way - ford part list stating only one...
15-10-2006 | 03:05 PM
How do you know 100% for sure your car is standard...? I doubt very much Ford used strips like shown in your picture.
What do you suggest that hole on the slam panel is for then...?
155lee
06-09-2016 11:10 AM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
gambo08
Fiesta RS1800/RS Turbo
16-09-2015 08:10 PM
phs84
15-09-2015 05:30 PM
focus2351
09-09-2015 09:33 PM
