New Engine Loom - Advice?
Im looking at getting a new Engine Loom, mines very tatty, and ive been having some problems with the car, so decided to get a new loom seen as ive changed everything else
How easy is it to fit an engine loom? much soldering etc.. wire chopping. Ive been told that Ryan on the board is the best place to get them from so will be talking to him soon about prices etc..
Also what would you recommend to have done etc, i.e dizzy less ignition, boost controler, etc.. as im a bit unsure what to go for, or whether just to go for a standard loom setup???
That looks a right knightmare
did the loom that you bought plug in straight forward? or do you have to cut wires etc? I was thinking it should pretty much just plug in apart from the main live, ignition wires etc?
What did you have to change for dizzyless ignition? get the ecu modded?
Yeah my car now effectively runs stand alone engine management, my loom has its own relays fuses etc, nothing goes via the fuse box any more...
I run a pectel board for dizzyless..
yeah lots of cutting and solderig
Originally Posted by rsdene
mate just a car looms uk loom, awesome bit of kit. i can remember the bloke name that sells them i try and find out
http://cgi.ebay.co.uk/New-Custom-For...QQcmdZViewItem
RSdene did u fit one urself? is it easy?
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
