dump valve problem
Old Sep 8, 2006 | 09:38 PM
vodoo1's Avatar
vodoo1
Default dump valve problem
fitted a dump valve to my bros large turbo escos today but its no good , fitted it in to top intercooler hose left hand side of the engine bay by the front panel have run a vacum hose to the inlet , as soon as you start the engine the diaphram opens up letting boost out via the dump valve , its opening when it should be shut and shutting off when it should be opening up brought it off here its a dv26 the right one for the YB im a bit stuck
Old Sep 9, 2006 | 08:59 AM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
thats how they usually work i think??? is open till you pres the acc pedal
Old Sep 9, 2006 | 10:04 AM
Rippers's Avatar
Rippers
Monte Geek
Yep open on idle, shut on throttle.. also expect a noisey wine on idle and the odd kid shouting chav at you as you drive past
Old Sep 9, 2006 | 12:35 PM
adamski frst
you love it
Old Sep 9, 2006 | 12:39 PM
kjc300's Avatar
kjc300
The twin piston ones stay shut
Old Sep 9, 2006 | 01:00 PM
cos jon's Avatar
cos jon
Just take it off and plug up the hose, sounds so much better without them..........
Old Sep 9, 2006 | 02:40 PM
Rippers's Avatar
Rippers
Monte Geek
you love it
Actually I do like putting it back on every now and then.. but last time I did I felt ashamed when someone walking along the street shouted chav at me
Its only a bit of fun at the end of the day
Old Sep 9, 2006 | 05:53 PM
Gary F's Avatar
Gary F
Old Sep 9, 2006 | 07:05 PM
vodoo1's Avatar
vodoo1
he used to drive a bmw so he's used to that
Old Sep 9, 2006 | 08:18 PM
adamski frst
no its usually 'look at that ugly **nt in the bmw'
Old Sep 15, 2006 | 08:52 PM
rsj's Avatar
rsj
yeah mines a baily dv26 that opens on idle...........when its fitted that is
Old Sep 16, 2006 | 11:30 AM
AJC's Avatar
AJC
Default Re: dump valve problem
left hand side of the engine, should be right hand side near the header tank mate
15
Oct 7, 2015 03:43 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
