Amal problem
Old Jun 25, 2006 | 11:28 AM
JanDK's Avatar
JanDK
Default Amal problem
Hi
My escort cosworth´s have been "bypassed" with an ordenary on/off switchvalve (low/highboost). I now put in a collinschip, and would like my amal to work out, with what ever kind of overboost it may give. But the o-ring in it is cracked and the valve don´t seem to click at all!! When connected the turbo makes MASSIVE overboost , like the amal don´t work out, but how can I make a safe check??
Can I see anything with my FLUKE if I put the pins into the amal-plug??
Can I give the amal 12v without killing it for sure?? and hear a click??
If my amal is dead... then I might need a secondhand well working amal with "snapplug" connection, for my escort
Could a boostcontroller be a solution to??
Old Jun 25, 2006 | 11:54 AM
THE RADMAN's Avatar
THE RADMAN
easy way to test it is take it apart and give it a live and earth from the battery and see if it opens and closes
Old Jun 25, 2006 | 12:32 PM
JanDK's Avatar
JanDK
Thanks radman... thought so
How about the seal (o-ring).. is only a dirt seal.. or is it very impotant/nessesary to be in top condition so there are no leaks. As I se it, it is in line from compressorhousing and actuator.
Old Jun 26, 2006 | 08:29 AM
JanDK's Avatar
JanDK
Think the amal is very dead!!!
Would a boostcontroller be something to go fore??? or "just" a ned amal???
I am "only" running 1,5 bar ... nothing serious
Old Jun 26, 2006 | 09:55 AM
DaveEscos's Avatar
DaveEscos
I have an Esc Cos amal / elekron valve available if needed
Old Jun 26, 2006 | 10:16 AM
JanDK's Avatar
JanDK
uhmm .. I will be back later this day Dave.. I am just have to make sure.. absolutly sure that there are no signal in the plug.
The one you have are NOT the same as on a Saphirre, correct?
Old Jun 27, 2006 | 03:13 PM
JanDK's Avatar
JanDK
Hi Dave
My Amal works !!!! It click like it have never clicked before thats good!!
It have unfortunately not been possible for me to check what ever kind of signal there are coming out of the wireing .. maybe nothing.
So I don´t need your amal at this time Dave.. thansk but no thanks
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
rs_jim
Sep 19, 2015 08:41 PM
