Inlet Manifold Gasket
29-05-2006, 06:30 PM
How much of a job is it to change the above on a st EsCos as mine is in need of doing
29-05-2006, 07:03 PM
easy enough if you have a hand like Jeremy Beadle.
Just a bit of a squeeze to get your hand in at the nuts right under the inlet manifold. Top
bolts are easy to get at.
Get a Cometic gasket to fit back onto it.
29-05-2006, 07:30 PM
Can you get away with leaving the plenum on or does it all have to come off?
29-05-2006, 07:32 PM
leave it all together,no need to split it.
29-05-2006, 07:34 PM
Excellent news, thanks for that dave
29-05-2006, 07:35 PM
29-05-2006, 09:11 PM
if you split it,it does make things a lot easier to get at,but i can guarantee youll have a couple hundred scratches by the time youve done
30-05-2006, 08:22 AM
easier to take the head off
30-05-2006, 01:41 PM
Quote:
Full of good idea's aint ya!!
Ps use an angled stubby rachet, that what i used Sat morning!
30-05-2006, 07:42 PM
Bit harder if you got ac as the alloy pipes dont flex much! But can be on and off in about 1.5 - 2 hours and like dave cos says defo get cometic gaskets as the standard ones nearly always go again.
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DAZZER
30-09-2015 08:43 PM
caprixpack
25-09-2015 07:53 PM
