dont know as i havent got a guage yet,lol,im having boost probs at the moment,one minute itll run full boost then the next it wont go above 1 bar,few minutes later its fine again! it looks like somethings limiting the boost to the safety setting,at first i thought it might be the fact that ive got my aircon rad in front of the 500 size intercooler and things could be getting too hot,but it does it with the aircon off as well so thats nothing to do with it,ive checked the amal valve had it apart checked it works,checked all the hoses to it etc so running out of ideas now,also renewed a/c/temp sensor,any ideas folks?
Ford decided that the optimum air temperature for maximum boost was about 40 degrees C and therefore reduced the boost at lower and higher temperatures.
right,ive got a cheapo temp sensor guage just to do a few tests,as i cant afford a pectel [one day,lol] what sort of temps should i be looking for? ie whats normal [ish] with a 500 type cooler?
rigged up my sensor and getting readings of 19-25 even the aircon only makes a couple of degrees difference, i did leave it idling with aircon on full and it eventually got to 38 but as soon as you drive the car its straight down to low 20's so its not excessive charge temps then,any ideas ?
