Cutting Out Under Cornering...??
Post Miester !
I am having a prob with the escos cutting out when cornering, soon as you
open the throttle the boost comes in then it cuts out, but if you do it on a
straight its fine
Starting to think it might be the fuel pump ??
Anybody had anything similar ?
Al..........
straight its fine
Al..........
hi al .i get same prob with mine, i put it down to being low on fuel but you say yours does it with full tank. just recently had prob with idle control valve ,it was spluttering in morning till it got warm then it would cut out some times when coming to stop.cleaned it out read fault codes on ECU came up with lamba fault .but noticed temp sensor reading droping down from 88 to -17 degrees .but don't think thats has anything to do with wot you and myself are getting .have you changed your plugs yet. MARK
Post Miester !
Are Escort Prone to fuel surge ??
Cos if i feather the throttle out and build up the revs its fine once you nail it..
My pump is a bit noisy sometimes tho, and the car feels a bit hesitant at low revs.
Al.........
Al.........
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
cossirob
16-09-2015 07:39 PM
