diffrence beetween t35 and t25 silicone boost set?
Old May 7, 2006 | 08:47 AM
Escort1.8si's Avatar
Escort1.8si
Default diffrence beetween t35 and t25 silicone boost set?
hello guys
Just wondering what is the diffrence beetween t25 and t35 boost sets as i will be fitting a t35 in nearest future on my t25 equiped car. But isnt it somthing with the throttle being bigger on st so i wont get the t35 boost hose on to it?
Old May 7, 2006 | 09:29 AM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
the tb on the t25 is bigger yes and also the ind pipe is different on the t28 too... i think there the same bar that but don't quote me depends on what size pipe cooler you have too etc
HTH
Ad
Old May 7, 2006 | 10:30 AM
THE RADMAN's Avatar
THE RADMAN
t35 turbo hose is bigger diam and longer,turbo to intercooler is bigger diam,and shorter as the intercooler has the chargecooler part on the end where as the small t doesnt, and throttle body hose is slightly different,apart from that theyre the same,lol
Old May 7, 2006 | 07:30 PM
tim10_10's Avatar
tim10_10
I have a t35 set on my small turbo inlet, tight fit but does go on. I ended up fitting a large turbo charge cooler because as radman says the LT turbo to cooler hoseis smaller than the ST.
Old May 7, 2006 | 09:12 PM
Escort1.8si
ok thanks for replys guys
JK12
33
Apr 26, 2021 12:09 PM
Adam Graham
Sep 6, 2015 06:04 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
