standard airbox, size question?
is there any difference in the size of the box and hoses in a small and large turbo cossie? need a standard airbox, been offered one but it's off a small turbo
If you can get hold of the ST airbox, I can probably modify it for you (if the plate is removable, as you can insert an alloy adapter (I have these made to convert LT airbox to accept 76mm T4 hose ). Could do one to fit 65mm T3/4 hose...
borboyous
22-08-2015 11:17 AM
