Blue smoke
Blue smoke
My cossie is starting to blow a little blue smoke out when on full boost mainly in the lower gears any ideas what could be at fault?
also my oil reading on the dash is around the middle mark on tick over but lately when ive been stuck in traffic it is starting to go a bit low can any one give me any advise
can you give a better description of when your getting the smoke, so youve said at full boost in the lower gears, what boost are you running? do you see any smoke on idle or on the overrun? are you seeing most smoke while boost is building or when max boost is reached?
maybe your turbo seals are letting alittle oil past causing some burning, pull off the induction hose to the front of the turbo is their any movement in the turbine, side to side in and out? sorry for all the questions just trying to help you sort this asap
i remember when mine smoked alittle and on further inspection the oil was way over the max, i replaced with fresh oil at the correct level and it was fine.
turbo
wouldnt worry about the lower oil pressure at idke when hot, its just wheere the oil has thinned out so much, presumably you are running correct grade?? ie 15/50 or 15/60 etc
That's pretty strange, usually turbos only smoke at full boost when theyt are completly knackered.
Idle? off boost all right too? Cold start? Warm start?
It may be breather problem too. What setup are you running?
milkmanif you can actually see it in rear view mirror it's big issue. I wouldn't drive it like that. I would say 99% it's turbo or breather system.
Originally Posted by Damo V
Strange 27k car having had a new turbo... at what? 18k miles??
Probably woud require some cold start full boost runs and then hot shut-offs. Still unusuall.
Steve Escos
01-10-2015 06:57 AM
