Front Bumper
Front Bumper
Started to take off the front bumper to replace the clips that had broken causing it to drop. Got the bolts out from the front and the clips from the sides, but the two under underneath are stripped. So going to try and drill them out tonight, oh joy.
Nowt ever going as planned
Had three in the front, (one behind number plate), two clips on either side, and two up and under. These two under are the two I can't get out, and appear to be holdin the bumper on?
you dont take any out the front,or from under the number plate,the ones under the plate are the height adjusters,look underneath and behind the bumper at the chassis rails,right at the ends of these are 2 large bolts,remove the rear 2 bolts and loosen the front 2,bumper then pull out and off car.dont forget to undo h/lamp squirter pipe as well
this should help you,you can see the rear bolt removed and one loosened from the bumper bracket,a previous owner had tried removing my height adjusters and stripped the thread thats why you can see a new bolt in the pic
Originally Posted by THE RADMAN
yours must have been removed and had the captive welds broke off geert,9 times out of ten they will usually strip the thread before the welds snap off
Loads less hassle then those 4 bolts you are talking about.
it will be now geert,but not if your welds had still been in place
You will probably be right on that one Nick as you know SOOO much about the Esc Cos.
Does anyone know if the brackets that slide into the chassis legs on the back of the front bumper available seperately as I've knackered mine when I've taken the bumper off? Phoned ford and they don't seem to have aclue what part I was talking about..
only available with bumper im afraid do you need both as i may be able to get some, not sure on price though
you will have to remove sumpguard or at least the front part of it to access bumper bolts iirc,prob easier to remove whole thing as the bolts that hold the 2 pieces together normally seize up,no need to remove ducts as these will stay bolted to cross member
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
