Anyone know L789 YDS? - answer from seller!
As seen here.....?
http://cgi.ebay.co.uk/1994-FORD-ESCO...QQcmdZViewItem
As i should start going to have a look at a few coosie to get a feel for them, so i'll kniow when i find "the one" , i just wondered if anyone knows anything about this?
Its been on ebay a few times though, and does mention a miss, and minor rust???- and the window washer doesn't work???
cheers guys
cheers guys
Looks like it was already sold on 20th of feb as both left feedback to say the deal was complete??
Bit confusing really. Maybe the buyer gave it back for whatever reason??
used to be someones on here they offered it me i while back when i was looking for one, i thought it was ok never viewed it as i'd bought mine when he offered it me.... may be worth a view??
just check what actually needs doing on it, i know it has a good spec just depends on how the engine is now?? may have changed hands since the guy offered me it??
Well, sent him a mail, and mentioned that it used to (or may still) belong to a guy on here...
See what he replys I guess...
cheers!
Edited to add this: https://passionford.com/forum/viewto...mperial+imp%2A
the plot thickens- belongs to terranova on here- as seen above....
cheers!
Yea, it used to belong to deano. Hes on here and the FEOC. He regrettably sold it a while back, but not long later the lad was trying to sell it on. Dont know why, but deano really did look after the car and spent a small fortune on it.
Hope it helps
Hope it helps
Not sure if this helps. I was going to go and view this but it sold. The chap that did own it (about 6 months ago) had a complete repaint but not the roof. Allso it had the misfire then so I guess its not just a coilpack.
No, shill Bidding, which is unscrupulous and against EBays rules..
Well, asked a question, and got a reply along these lines.....
MSD did the rebuild and setup but has been set up again at PTS and the rust is small by the nearside rear sideskirt and it is hpi clear but check for yourself and has had no pannels as far as i know and the missfire will be fixed by a COILPACK and if you knew anything you would know that is a better source of ignition so will cure it but read the treads on passion ford....
Now, i'm not too clued up on cossies, but from what i've read on Stu's coilpack thread, yes, a coilpack will solve the problem of there being a misfire, but is this due to having to run plug gaps that are too small, and a coipack conversion will solve this? - However, surley a mis won't be present if all of the ignition parts are renewed, and points to a fundemental problem elsewhere? By all means correct me if i'm wrong!
Oh, and was "sold" as he was trying to ensure a reserve was met, so was bumping up the price.....
Sooo, think i may have to give this veiwing a miss....
But, on a plus note i should be going to central day (its at the Pod in April isn't it, to have a lookski at any possible cars that are for sale!)
rsguy
44
29-09-2015 03:29 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
