draining coolant advice?
right well instead of paying someone ive done it myself, ive brought a brand new coolant tank, with looks wikid under the bonnet but i need to know what coolant to fill with?? is their any specific type, also mostly importantly, to bleed do i just undue the bleed screw on top of the water pump then fill to max and blow thro the tank till it comes out the bleed screw?
TO drain
drop the bottom rad hose off (O/S)
clean the system through Refill with fresh water warm up then drain again, then refill using 50/50mix with Ford antifreeze. IIRC its 7 ltrs in total?
put cap on run the car up, keep an eye on the gauge, feel ALL the water pipes to check they are hot, open bleed screw a small trickle of water will come out shut it off, keep running car thermostat will open, check by making sure rad is nice and warm throughout, keep running and fans will cut in... job done
allow to cool overnight and chack water level when cold add if necessary
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
