power steering fluid draining?
i want to drain the fluid to change the tank as mine is virtually black!! is their a drain pipe anywhere or do i havr to let it make a right royal mess everywhere?
on the rack i presume, mine is losing power steering fluid atm i need to get it in the air to see why its leaking maybe a rubber seal gone??
Right ... in this pic, you can see between the rad and crossmember, there is a lenght of black hose with metal unions each end its about a foot long and has that plastic curly stuff round it... at one end you can see it bolts to the P/S pump... that is the banjo bolt
OR
There is another solid metal hose to the left in the pic (In my pic its painted silver)which is fixed via a hose clip, IIRC this is the supply from the reservoir, so you could just get it all warmed up and thin, then drain here, refill, purge, warm up and drain again
HTH
OR
HTH
right just done this!! replaced the tank and new ps fluid!! looks the business, thats guys!!! i undid the banjo it was alot easier adn only made alittle mess!!
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
