Brake pedal feel on Escort... how's yours ?
Just curious, as mine is a bit spongious at the beginning (with a kind of "psss" noise), then very hard just after. In fact, i don't really like the feeling of the brake pedal in this car, i find it too hard and gives not enough feeling. I have Compbrake 4 pots callipers, braided hoses, but it was the same before with standard callipers and DS2500 pads. Is it the same for you all ?
will give it a try tomorrow
i also have a violent shaking in the steering wheel when catching brakes at around 60 mph, what can cause this shaking in the steering wheel ?
acutally re-reading what youve posted, you getting a bad vibration when braking at high speed, warped disc most likely. sorry didnt read yor post properly
but all my brakes are new, full new big brakes kit on front, and new discs + pads on rear, they all have around 200 miles max !!
well in fact it was already shaking before the new big brakes, that's why i upgraded the brakes in fact
and now with everything new, it's still shaking... so i'm sure it's not the discs nor the callipers nor the pads...
Pet,
have a good look at the brakes you have fitted and make sure you have fitted them right.
eg, the alloy space is the right way.
the steering wobbe could be the caliper rubbing the disc and the hard brake pressure could be the caliper pistons not moving.
had a similar thing on mine the other day.
found out i have got 32mm discs instead of 28mm discs and the caliper was very slightly rubbing on the rotor!
have a good check.
have a good check.
1. pedal feel -> on mine it's nice and firm, not such gey, spoongy feel liike on many modern cars. But its very different to any other I've driven. The bleeding procedurte requires that you bleed the rear by pressing peda l half way ad turning ignition on - the hydraulic pump will bleed the rear by itself you only hold the pedal as it was. Fronts yu bleed normally - YOU SCHOULD CONSULT THE MANUAL. Braking system on Escos and Mazda GT-R is very unique.
2. Shaky steering underbraking is disc warping or similar. Check if the discs are good fit on the hubs, maybe one of the hubs needs cleaning, some rust maybe? It maybe that new discs aren't 100% straight and require skimming, but as you said it was there even before I would suspect problem with hub or damaged hub. Of course if you have any play anywhere is the suspention the problem will be much bigger. Do you feel the shaking more through your body or the steering?
My brakes are what I would call severe, you only have to touch them lightly, otherwise you'd be through the screen.
Re: Steering wheel shaking... I had the same prob you've got on a previous car Pet, it was a Mk V XR3i. Doing between 55-70mph, the steering wheel used to shake like hell. Had all wheels rebalanced both on and off the car, swapped wheels round, balanced again, tracking checked and still didn't cure it.
The problem was finally diagnosed as a driveshaft. Apparently, when you fit bigger wheels, it alters the original angle of how the driveshaft sits in the socket, this wears out and makes the driveshaft loose in the socket.... (I think that's how it was explained to me). Anyway it cured the problem when I had a new exchange driveshaft fitted.
Originally Posted by Damo V
Have you got a workshop manual?
I cant place mine right now, it regards IGN on and off when doing rear brakes...
Do explain.....I've got to change my fluid soon.
IMO wobble under braking would be down to discs or as above front suspension bushes
Redkop is right about a wobble under normal cruising speeds being inner driveshaft joint, usually more obvious on slight bends at high speed...
Jason, ask paul if you can borrow his manual
to bleed the rears the system is self purge, you need to switch ign on then hold the brake pedal down
no longer than 15 seconds or youhave to let the pump cool down
peice of piss
ps , my pedal is firm
peice of piss
i will do this then, as i used normal bleeding procedure for rear too (ie engine on, and push several times until pedal is hard)
what problem could it cause to bleed the rear like you do on other cars ?
Hi Pet,
If it did this before the brakes were fitted, it could be a warped hub, as these are known to happen on Escort Cossies. Unfortunately they are a part that is no longer serviced .
You can check the hub "run-out" with a dial gauge.
In the meantime, I take it that before you fitted the brakes, you cleaned the hubs meticulously - and by this I mean that you removed ALL the wheel studs (if you don't, then you can't remove any build up around the studs properly) and faced the hub with a wire brush / emery cloth so that it was as flat as a flat thing and as smooth as a baby's bottom ? If not, it could be that a build up of dust / rust on the hub is causing your "run-out" issues .
Hi Pet,
Originally Posted by Azrael
Hi Pet,
Never had a problem personally .
it never rains nor snows where i'm leaving, so corrosion is not usually an issue. But the hubs may be a guess i imagine, but this way the car should chatter when going foward without braking too, no ?
Petrucci all things like hhub warping get A OT worse when braking, so you may not feel it while driving. Think abot how git is the diameter of the part of the disc that has contact wich the wheel and how big is the diameter of the part that has contact with pads. So this may be the reason.
