Brake lights on while driving
10-03-2006 | 06:11 AM
My brake lights stay on while driving !!!
Any ideas what would cause this or better yet does it work with a switch ?
If so where is it?
10-03-2006 | 06:56 AM
most cars have a switch on the brake pedal, check that, must be stuck/broke.
10-03-2006 | 08:44 AM
the switch above the brake pedal may have come out [its only a twist in fit] or it may just want adjusting
10-03-2006 | 08:58 AM
thanks guys will look tonight
10-03-2006 | 12:48 PM
to sort this you will need some blu tac and a 2 p piece.
stick it onto the pedal so it makes the switch
10-03-2006 | 06:17 PM
why not just adjust the switch to the correct position?
10-03-2006 | 06:42 PM
what he said... You have to crawl under there to fit the 2p so why not just adjust the switch? (Or replace it)
Timmy74
Ford Mondeo Including ST
28-08-2015 01:21 PM
borboyous
22-08-2015 11:17 AM
