boost level
Old Mar 8, 2006 | 04:48 PM
k3ocb's Avatar
k3ocb
Default boost level
I drove my car today properly for the first time after an extensive rebuild over winter. I will attach photos soon. Anyway the car drove brilliantly but I wondered what psi boost is ok to run. The engine spec is stage III with pectel management, rs 5oo intercooler water injection etc etc.
Thanks......
Old Mar 8, 2006 | 05:17 PM
Damo V's Avatar
Damo V
depends on the chip have you rebuiult enine?
Are you asking what boost for running in??
If so just loop the actuator to the compressor housing for 500 miles then connect it all back up as per normal and run 10 for 250 the a little more then setup
Old Mar 8, 2006 | 05:51 PM
rapidcossie's Avatar
rapidcossie
i wouldn run any boost until i had it checked by a pro..
alotof things can change with a rebuild.
Old Mar 8, 2006 | 06:03 PM
DaveEscos's Avatar
DaveEscos
run of the mill stg 3 boost is around 22-24 psi
Old Mar 8, 2006 | 07:26 PM
barry0777's Avatar
barry0777
what dose this do if you have theactator looped over to the compresser????
Old Mar 9, 2006 | 02:49 PM
Damo V's Avatar
Damo V
JUst gives minimal boost
Old Mar 9, 2006 | 03:14 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Also, you need an accurate boost guage, not the "finger in the air" standard item .
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
