Missfire - please help
Ok , i have spent nearly 50 hrs trying to solve this one.
At 1,3 bar at 5800rpm it starts braking down until 6200 rpm there is a complete brake down almost like a rev limiter.
At 1 bar it is fairly clean.
I have check and replaced :
Plug leads
Plugs - now i have KHS Iridium i45 with 0,6 mm gap
MSD twin tower coils x 2
MSD Dis 2 Ignition amplifier
Set Crank angle sensor to 0,8 mm ( spec 0,6 to 1mm)
Set Distribitor to 0.15 mm magnetic pickup
Checked distibutor and coils on a bench test.
Set up distibutor as follows :
TDC on the first pickup tooth after the cut in the crank pulley. Turn distributor to line up with a slight cut mark on the round base . Near perfect alignment.
Is there any knock sensor on these cars ?
Can a air or water temp sensor cause this ?
Any help or ideas please , please ,please
Plug leads
have you checked your fuel pressure?? i had a similar problem with mine! there was a miss fire at 5500rpm but if i kept my foot in it went again as the fuel pressure had a moments chance to get back up again!!!! when i put it on the rollers with there c02 machine it was blindingly obvious that there wasnt enough fuel so i uprated the pump then back on the rollers and hey presto it worked fine
Ginge !
23
28-05-2005 01:06 PM
